![]() | Home > Maintenance & Mods (L322) > Steering column ignition problem |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269
Some reading here: http://www.fullfatrr.com/forum/topic40178.html?highlight=column John
| AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186
Weegie many thanks.Noticed that can jumper connector 0255 and solve problem:) |
| mrsamram Member Since: 30 Jan 2015 Location: Mumbai Posts: 5
i had the same issue in mine, the key wont turn, the best way to check to make sure its the column is to disconnect the battery and reconnect and then try turning, should work, there is a way to drill a hole and solve this problem without replacing the column |
Thanks mrsamram.Unfo drilling didnot work for me.also trick with connector 0255 as is for later models.Charged and reconnected battery still nothing.Only solution seems to be either replacement of steering column or for cheaper solution "advancedkey" which as per supplier info is fully compatible with rr |
