Home > Maintenance & Mods (L322) > Steering column ignition problem
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Most probably have to replace steering column as key is not turning.
Googling to find out possible cheap solutions found this:https://advancedkeys.com/index.htm
Wondering if have you ever heart something about such a solution
Any reply will be most welcome
Post #441514 14th Jun 2017 4:12pm
Weegie
Some reading here: http://www.fullfatrr.com/forum/topic40178.html?highlight=column John
GAP iiD BT-Sold
Post #441520 14th Jun 2017 5:10pm
AKIS
Weegie many thanks.Noticed that can jumper connector 0255 and solve problem:)
Post #441574 15th Jun 2017 12:32pm
mrsamram
India 2003 Range Rover Vogue 4.4 V8 Alaska White
dont replace the column
i had the same issue in mine, the key wont turn, the best way to check to make sure its the column is to disconnect the battery and reconnect and then try turning, should work, there is a way to drill a hole and solve this problem without replacing the column
Post #442755 26th Jun 2017 2:41pm
mrsamram
heres the solution
https://blackbox-solutions.com/photos/L322lock.pdf
Post #442756 26th Jun 2017 2:42pm
AKIS
Thanks mrsamram.Unfo drilling didnot work for me.also trick with connector 0255 as is for later models.Charged and reconnected battery still nothing.Only solution seems to be either replacement of steering column or for cheaper solution "advancedkey" which as per supplier info is fully compatible with rr
Post #442851 27th Jun 2017 12:28pm
