Home > Technical (L322) > Is remote heat also remote cool?
mjdronfield
I know you can program the timer for the cooling to come on at a certain time, but can you also use the remote fob for the heater to do it?
There is nothing I can see in the manual, but if you look in a Webasto manual, it gets mentioned. Not sure if the RR has remote cool..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #441858 18th Jun 2017 9:18am
GGDR
On the home screen you can go timed climate then timed cool I think.
So maybe with the right combination of buttons the remote can activate.
In this weather I'm also using the long press to unlock which opens all windows and sunroof.
. Cheers, Greg
Post #441864 18th Jun 2017 10:44am
Rob99
I'm also using the long press to open all windows/sunroof but does anyone know (perhaps via IID tool) whether you can just have it opening the windows.
My Westie has to sit under a tree on our drive and the birds are very good shots..... Evil or Very Mad
I don't want an open sunroof to be an easy target...... Shocked 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #441866 18th Jun 2017 10:55am
andygts
pretty sure the remote heating will only activate the fuel burner if the cabin temp is below a certain temp, otherwise it just activates the blower.
easy way to find out, activate it and you'll hear the burner kick in and smell it if it does turn on. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #441869 18th Jun 2017 11:03am
Eirik34
Norway
When programming pre cooling: Isn't it just the air blower that is turned on to "cool down" the cabin? I didn't think that the air-conditioning would operate before the engine was started?
Post #441872 18th Jun 2017 11:32am
GGDR
Yes timed cooling is just running the blower. Cheers, Greg
Post #441873 18th Jun 2017 11:37am
mjdronfield
I shall have to try it. I know it only blows the hot air out, it doesn't actually cool.
I have used the timed cooling from the screen, just thought it might come on with the fob, even though it's nothing to do with the Webasto heater..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #441882 18th Jun 2017 12:38pm
stu
The newer smaller T91 remotes will only do the fuel burning heater. The older style T90 remotes could do heat and cold.
As stated the air con will not work without the engine running Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #441889 18th Jun 2017 1:46pm
mjdronfield
Just tried it and it works....LED in remote fob is flashing green instead of red, and the car is venting itself.... cool !
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #441891 18th Jun 2017 2:10pm
stu
Well you learn something new every day! But on a day like today will you not just be blowing warm air around? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #441897 18th Jun 2017 4:22pm
mjdronfield
indeed, just blowing the air about, but tomorrow when it's been sat in the sun all day, I can activate it from the office so at least it's not steaming hot when I get in it to come home.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #441899 18th Jun 2017 4:27pm
stu
Is there a difference between a webasto remote and a L/R one?
This is the information from the user hand book, are things model year related too?
Mine only goes green for on red for off and orange when battery low as per this.
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #441900 18th Jun 2017 4:36pm
mjdronfield
I would have thought yours was the same as mine. It came with the car....
Have you tried the change mode instructions from my image above?
I didn't think it would actually work if I'm honest, but read it in a Webasto manual I found online. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #441906 18th Jun 2017 5:07pm
stu
Yes I tried pressing both buttons together twice in two seconds and it makes no difference! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #441911 18th Jun 2017 5:48pm
