![]() | Home > Technical (L322) > Is remote heat also remote cool? |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980
I know you can program the timer for the cooling to come on at a certain time, but can you also use the remote fob for the heater to do it?
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1476
I'm also using the long press to open all windows/sunroof but does anyone know (perhaps via IID tool) whether you can just have it opening the windows.
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366
pretty sure the remote heating will only activate the fuel burner if the cabin temp is below a certain temp, otherwise it just activates the blower.
| Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443
When programming pre cooling: Isn't it just the air blower that is turned on to "cool down" the cabin? I didn't think that the air-conditioning would operate before the engine was started? |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555
Yes timed cooling is just running the blower. Cheers, Greg
I shall have to try it. I know it only blows the hot air out, it doesn't actually cool.
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
The newer smaller T91 remotes will only do the fuel burning heater. The older style T90 remotes could do heat and cold.
Just tried it and it works....LED in remote fob is flashing green instead of red, and the car is venting itself.... cool !
Well you learn something new every day! But on a day like today will you not just be blowing warm air around? Current: TDV8 (3.6) RRS HSE
indeed, just blowing the air about, but tomorrow when it's been sat in the sun all day, I can activate it from the office so at least it's not steaming hot when I get in it to come home.
Is there a difference between a webasto remote and a L/R one?
I would have thought yours was the same as mine. It came with the car....
Yes I tried pressing both buttons together twice in two seconds and it makes no difference! Current: TDV8 (3.6) RRS HSE
