Home > Maintenance & Mods (L322) > Urgent help needed please.
Siclark
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
I've just replaced the fuel pump and fuel filter today on my 2004 4.4 V8 Autobiography. I've just started it up and it's misfiring horribly, revs going up and down around 1000 - 1200 rpm, throttle does nothing and it's saying "Engine failsafe prog" !
Can anyone help me as I'm stuck now, I double checked everything when reporting so as far as I know all fuel pipes should be fitted ok.
Post #441799 17th Jun 2017 6:03pm
Siclark
Anyone ?
Post #441867 18th Jun 2017 10:56am
disconnect or clean the MAF.. ... - .- -.
Post #441881 18th Jun 2017 12:34pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Did you let it run for a while to clear any air locks?
Post #441885 18th Jun 2017 1:09pm
Siclark
Runs perfectly with maf disconnected, revs as normal and no "Engine Failsafe prog". Reconnect maf and the problem returns along with the "Engine Failsafe prog".
Post #441890 18th Jun 2017 1:53pm
Siclark
So after cleaning the Maf, it runs ok if I start it up with it disconnected and now when I plug the Mad back in it continues to run ok. If I then switch the engine off then restart, the fault returns along with the "Engine Failsafe prog".
Post #441893 18th Jun 2017 3:15pm
Siclark
After cleaning the Maf again, it now appears to be running fine. Been for a 30 minute drive and there's no issues. Switched it off and back on, starts fine. Just need to wait and see what it starts like from cold.
Post #441901 18th Jun 2017 4:39pm
Danwilderspin
I would buy a new Bosch maf from cp4l it was under £100 when I got one - had to clean it every couple of months just got annoying now I don't need to worry.
Post #441975 19th Jun 2017 10:31am
Siclark
Ordered a new Maf from Euro car parts for £86 using discount code. For a Bosch one I didn't think that was too bad.
Post #442007 19th Jun 2017 5:14pm
