![]() | Home > Technical (L322) > Airbag warning light but no fault?? |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286
Interesting one this wondered if anyone has any ideas the airbag warning light is on but when I run the 11D tool no faults are registered also when I go into the ipc I can't turn on or off any of the warning lights - am I looking at an ecu on the way out or is there a simple reset ?
| Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433
could it be passenger airbag is switch off hence no fault? |
No it was all fine till I changed all the pulleys and water pump battery showing 12,5 charging t 14v so not sure |
Updater stripped it all down and tested each bit of the system and I have a fubarred airbag thought it was going to be a switch but no its the airbag ah well at least I know |
