Home > Technical (L322) > Airbag warning light but no fault??
Sandyt
Interesting one this wondered if anyone has any ideas the airbag warning light is on but when I run the 11D tool no faults are registered also when I go into the ipc I can't turn on or off any of the warning lights - am I looking at an ecu on the way out or is there a simple reset ?
Any info welcomed
Post #441903 18th Jun 2017 4:56pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
could it be passenger airbag is switch off hence no fault?
Post #441938 18th Jun 2017 9:28pm
Sandyt
No it was all fine till I changed all the pulleys and water pump battery showing 12,5 charging t 14v so not sure
Post #441939 18th Jun 2017 9:39pm
Sandyt
Updater stripped it all down and tested each bit of the system and I have a fubarred airbag thought it was going to be a switch but no its the airbag ah well at least I know
Post #442253 21st Jun 2017 11:29pm
