Home > Maintenance & Mods (L322) > side vents
Page 1 of 3 123>
side vents
i had some old 2 fin side vents lying around so i decided to paint them and put them on the westie to see how they looked...
before,
after,
what do you think? ... - .- -.
Post #442080 20th Jun 2017 12:39pm
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
A great improvement 👍
I need some of these
Post #442081 20th Jun 2017 12:43pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
+ 1 from me Very Happy 2009 Stornoway Grey Vogue TDV8
Post #442085 20th Jun 2017 1:13pm
Rob99
They look good Stan, subtle and very stealth-like, almost like a Black edition Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #442086 20th Jun 2017 1:34pm
thanks all.. Wink ... - .- -.
Post #442088 20th Jun 2017 1:38pm
nino_nino
It looks great, I was thinking of doing the same, are they direct replacement or do you need to modify them some?
Post #442094 20th Jun 2017 2:23pm
straight swap, this is the beauty of the L322 where some of the 2002 bits fit all the way up to 2012... ... - .- -.
Post #442095 20th Jun 2017 3:03pm
buffalo4
Anyone got any of these lying around ?
Post #442097 20th Jun 2017 3:11pm
got the itch then Ian Laughing ... - .- -.
Post #442098 20th Jun 2017 3:16pm
buffalo4
Looks 👅
Post #442099 20th Jun 2017 3:23pm
GGDR
Stan I was always a fan of the originals. But the newer style have grown on me quite a lot. But I think fitting the older one dates the your late model and creates a partial facelift look. So if up to me I'd go back. Cheers, Greg
. Cheers, Greg
Post #442104 20th Jun 2017 3:51pm
^ by the same token they look a bit 405 esquire so it could go the other way.
Personally I like either, the old style vents do add to the black on black on black on black look...... There is nothing that can't be fixed with a hammer😜😜
Post #442113 20th Jun 2017 5:00pm
Webbie
Side fin envy. I always preferred the original L332 style.
Post #442118 20th Jun 2017 5:13pm
i see what you mean greg but as mark says it could look l405'ish...it does look better in real life though and i'll see if the look grows on me , if not then its an easy change back... ... - .- -.
Post #442123 20th Jun 2017 5:41pm
mjdronfield
You will be upgrading to the 2002 front end next!
I like the fins, just not sure about the colour coding, but depends if you are going for the stealth look.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #442127 20th Jun 2017 6:01pm
Page 1 of 3 123>
