![]() | Home > Maintenance & Mods (L322) > side vents |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
i had some old 2 fin side vents lying around so i decided to paint them and put them on the westie to see how they looked...
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
A great improvement 👍
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
+ 1 from me |
thanks all.. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
It looks great, I was thinking of doing the same, are they direct replacement or do you need to modify them some? |
straight swap, this is the beauty of the L322 where some of the 2002 bits fit all the way up to 2012... ... - .- -.
Anyone got any of these lying around ? |
got the itch then Ian |
Looks 👅 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Stan I was always a fan of the originals. But the newer style have grown on me quite a lot. But I think fitting the older one dates the your late model and creates a partial facelift look. So if up to me I'd go back. Cheers, Greg
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8771 ![]() ![]() ![]() |
^ by the same token they look a bit 405 esquire so it could go the other way.
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
Side fin envy. I always preferred the original L332 style. |
i see what you mean greg but as mark says it could look l405'ish...it does look better in real life though and i'll see if the look grows on me , if not then its an easy change back... ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
You will be upgrading to the 2002 front end next!
