|  | Home > General > Loving my cooled seats in this weather ! |
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367    | Best invention ever, I use mine quite alot.
|  26th May 2017 9:23pm |
| Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115      | In my previous cars even with AC full on you'd still finish you journey stuck to the seat, cool seats stop that. | ||
|  26th May 2017 9:32pm |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927      | How cool do the cooled seats get, used mine for the first time yesterday and I could feel a bit of cold air on the base, but nothing in the back! Current: TDV8 (3.6) RRS HSE
|  20th Jun 2017 10:07pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | You can have it on:  BASE / BACK / BOTH so hit the button on the front of the dial and see if that makes sense.
|  20th Jun 2017 10:18pm |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927      | Thanks for the reply, I had both the base and back lights on  and all the blue lights on for max cooling! Will have a fiddle and compare the passengers to drivers seat as well Current: TDV8 (3.6) RRS HSE
|  20th Jun 2017 10:24pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | There is also a round filter that can use a clean out once in a while. Raise your seats up to max, stick your head under and you'll see it. A quarter turn removes it. Cheers, Greg
|  20th Jun 2017 10:36pm |
| Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115      | Mine take a few minutes to kick in and are not that cold, just enough to stop a sweaty crevice | ||
|  20th Jun 2017 10:43pm |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964      | The peltier cells don't have much range, about 7º below ambient and 9º above so the cooler you get the car the colder they will blow. 2008 MY Supercharged
|  21st Jun 2017 9:13am |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927      | thanks for all the answers, I located the filters and twisted them off this morning, don't look over dirty but suppose it would do no harm to change them, probably won't cost that much to replace.
|  21st Jun 2017 11:33am |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964      | Then you would have the Oxford leather sir,semi aniline was reserved for the VSE/AB even with the climactic seat option. 2008 MY Supercharged
|  21st Jun 2017 12:15pm |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690      | stu, no need to buy new filters, first vacuum filters well and than sok them in the mild soapy water, rinse and dry. good as new. | ||
|  21st Jun 2017 1:07pm |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927      | @Axle.. thanks for that! it's hell being in second class you know..  | ||
|  21st Jun 2017 1:20pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
