![]() | Home > General > Loving my cooled seats in this weather ! |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
Best invention ever, I use mine quite alot.
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 ![]() ![]() ![]() |
In my previous cars even with AC full on you'd still finish you journey stuck to the seat, cool seats stop that. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
How cool do the cooled seats get, used mine for the first time yesterday and I could feel a bit of cold air on the base, but nothing in the back! Current: TDV8 (3.6) RRS HSE
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
You can have it on: BASE / BACK / BOTH so hit the button on the front of the dial and see if that makes sense.
Thanks for the reply, I had both the base and back lights on and all the blue lights on for max cooling! Will have a fiddle and compare the passengers to drivers seat as well Current: TDV8 (3.6) RRS HSE
There is also a round filter that can use a clean out once in a while. Raise your seats up to max, stick your head under and you'll see it. A quarter turn removes it. Cheers, Greg
Mine take a few minutes to kick in and are not that cold, just enough to stop a sweaty crevice |
The peltier cells don't have much range, about 7º below ambient and 9º above so the cooler you get the car the colder they will blow. 2008 MY Supercharged
thanks for all the answers, I located the filters and twisted them off this morning, don't look over dirty but suppose it would do no harm to change them, probably won't cost that much to replace.
Then you would have the Oxford leather sir,semi aniline was reserved for the VSE/AB even with the climactic seat option. 2008 MY Supercharged
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
stu, no need to buy new filters, first vacuum filters well and than sok them in the mild soapy water, rinse and dry. good as new. |
@Axle.. thanks for that! it's hell being in second class you know.. |
