![]() | Home > Maintenance & Mods (L322) > Transmission Flush |
Has Member Since: 19 Jun 2017 Location: Leicester Posts: 18 ![]() ![]() ![]() |
Hi
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
Think i'd rather flush and drain it properly via gravity than vacuum pump it out. And as for flushing, it seems to make sense to me. I flush the engine every time I change the oil, so I would do the same with the gearbox. Especially considering the cost of a new box or rebuild.... |
You've made a point there Big Boy, if the additives that flush the engine are not harmful to the engine oil then surely the same goes for the trans cleaner... |
I'm led to believe the 'flush' is basically using double the amount of ATF needed. Drain. Fill. Drain. Refill. Plus filter of course. Depends on the gearbox type as to whether you can replace with the metal or plastic sump. |
Yes that's the double flush, that is fine no problem. It's the so called mega flush which uses the Wynns or Fortron machines which the tranny garages have a problem with. (Oops that last bit came out wrong |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
This might help.
PMSL!!! That must be why the Tranny garages prefer to suck it rather than let it dribble out of the bottom |
Oh Nastyyy |
Good write up in that thread Hamlet but that's what our 'boys' |
I think the simple answer is....if there is any doubt then don't do it. Stick to the recommended way.
After spending countless hours doing research worked out what some of the original LR dealer service parts are and best place to get them which could be useful to many here:
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 ![]() ![]() ![]() |
If you speak to Chris at Opie he will look after you. I was talking to him about Lifeguard 6 and Castrol Syntrax for my L322 earlier today. Tell him Ken at Milestone Motorsport recommended him. They apparently will price match and £17.75 is the cheapest I found for Lifeguard 6.
Nice one Ken, will give him a call |
Any advice on air filter, dealer versus oem non genuine etc? Bmw E36 328i M Sport Cabriolet
