Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005...
Page 12 of 20 <123 ... 111213 ... 181920>
ChrisHamblin
France 2004 Range Rover Vogue Td6 Stornoway Grey
Hi All,
First as with everyone, thanks for the info here, very very helpful!
I am most of the way through fitting a Sony unit with Android Auto and separate Amp for the factory subs. I also hope to get the original mic working for hands free. I have some photos and some more info on choices made which I will post when done but before then, if anyone can help with the following two questions it would be mightily appreciated!
1) Parking Sensor Live - I have installed a reversing cam but instead of picking up a reverse signal from the lights / gear selector - which would only be on when actually in reverse - I would like to pick up a feed from the parking sensors. These remain 'active' for a short period of time whilst manoeuvring, be that reversing or in drive, and thus would keep the reversing cam on during this same time. I think this will be much neater as a solution and more practical as well. As the LED on the parking sensors stays lit during this time, there must be a live wire there somewhere... but there are so many cables in that multiblock testing one by one would be hard and could cause some damage... so if anyone knows the magic colour that would be great?
2) Hand / Parking Brake Switch - As it is an Android Auto system, certain functions are restricted during drive. I would like to try this - I can always earth out the line at a later date if it annoys me... so therefore I need to find the switch feed for when the parking brake is on. Again any ideas of where I can find this without ripping the centre console to bits to expose the lever itself?
Car is MY2004 btw. Full Vogue spec.
Thanks guys... pics, update and report on the Sony setup to follow, just gotta get this sorted to finish it first!
Thanks,
Chris
Post #442887 27th Jun 2017 7:42pm
Pretty sure the mic will be the wrong impedance, I tried it and it was terrible on mine, I used a Parrot double mic self cancelling set up, worked well...
The PDC control box is in the right rear cubby hole behind the fuse box, it would be easier to get a feed from there, the dash light is probably can bus controlled...
The handbrake control really is a waste of time and too much effort for no gain, most of the systems are set to work UNLESS the wire is earthed so work anyway... Depending on the Android you are using there is also a setting to ignore it anyway, can't see the point of wiring something up that prevents you from doing something...!!
Good luck.... Pete
Post #442895 27th Jun 2017 8:54pm
ChrisHamblin
Hi Pete,
My car has had an old school phone kit in before and the mic wiring modified a bit... so not sure what they might mean. I will experience with caution!
You're probably right about the brake... I just like things to be done properly.
For the parking sensors... when you say right rear cubby... can you elaborate>
Thanks,
Chris
Post #442912 27th Jun 2017 11:45pm
Here you go, it's here, item 3...
Wiring diagram
Connector details, looks like you need pinout 7 on this connector, run it through a relay to power the rear camera... Thumbs Up
If you need more info, download Rave from the WIKI (Link top right of page under fullfatrr.com)
Good Luck...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #442914 28th Jun 2017 1:48am
ChrisHamblin
Thanks for that... managed to find a switched feed on the main connector block of the PDC controller... might be 5v as opposed to 12v but the head unit is happy with it. Now whenever the parking sensors are on - even if they are switched on manually with the car in park or neutral, the camera is activated. Obviously in normal reversing action it works as well.
I have a few pics of the wiring so I will post when I get the chance.
I also somewhat inadvertently found that the parking brake switch is very easily access under the cup . ash tray holder which easily pops out. I was actually routing a USB cable back to the arm rest but spotted that there. I have permanently switched the cable for now but left it accessible there just in case I ever feel the need for it to be correctly linked to the hand brake.
Thanks for the help, hope this info continues to build the resource for others!
Post #442980 28th Jun 2017 8:31pm
Thumbs Up Thumbs Up Pete
Post #442984 28th Jun 2017 9:07pm
Fox11
Australia 2005 Range Rover HSE Td6 Zambezi Silver
head unit
Gday folks,I have a different head unit,I don't have the sat unit in the back,My Ranger Rover is 2004-5 l322,I have lil buttons under the volume switch,I'm unsure weather this is the same install,An information would help,Thank you in Advance.
Regards
Post #444749 17th Jul 2017 7:24am
@ Fox11
You have the later touch screen version with MOST. You can't do the Android conversion with this one. Crying or Very sad .
Post #444755 17th Jul 2017 8:54am
Fox11
Thanks Joe,Whats the best way to put an after market sat nav in?besides the window mounted one?
Ive never seen a video on a update for my head unit.
thanks again Joe
Post #444759 17th Jul 2017 9:15am
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
fitting an Android
Great post.
With this replacement, we loose the information on the dash and the subwoofer right?
Cheers
Antonio
Post #447432 10th Aug 2017 8:27pm
You lose the information on the dash but you can wire in the subwoofer if you want to.... Pete
Post #447433 10th Aug 2017 8:35pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Are the photos from this post hiding somewhere?
Post #459789 6th Dec 2017 6:06am
miggit
PHOTOBUCKET!
Sorry to swear first thing in the morning, but there is only one word that explains where the photos went Shocked
However I did have a gander at the first page and Pete has uploaded the all important "speaker wiring list" and the rest of the connections are described, just not pictured anymore Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #459797 6th Dec 2017 9:02am
Yes, sorry about no pics, I had over 1,500 on photobucket, I even had to pay them to host before their weird decision as so many were looking at my posts I ran out of bandwidth, it was costing me a tenner a month anyway, then they want to charge a small fortune and as soon as they did this I tried to download all my photos from them and although they said I could it never worked, I tried for over a week to do it and it wouldn't let me...
I just haven't got the time to reload all of the photos some other way, if you want a specific photo then please PM me and I will try to find it in my archive but don't hold your breath as they are unsorted photos and over 3,000 and I haven't saved them all as I presumed they were there forever on PhotoBucket (replace the B with an F) to55ers.... Pete
Post #459812 6th Dec 2017 11:05am
doclees
So are all the pics uploaded here actually going somewhere else and subject to that other site's terms? What about YouTube video links? Are they safe from hijacking?
Post #459825 6th Dec 2017 3:07pm
