Home > Technical (L322) > Rotten front subframe
There is massive strength in the strut tops, they will hold the engine up no bother at all.
That rust has come through from the inside so be very careful about the "new" one you buy, it could be a month away from looking the same.
If it was me I would get it dipped to strip all the existing paint and surface rust off then a good inspection should reveal if it is OK, I'd then have it hot dipped galvanised, powder coating will only cover the outside and not provide any protection from where the rust is coming from, you could inject it with rust preventative but galvanising is pretty cheap and will make it last for years..
I'd also change the subframe mountings as a matter of course, and while it's out it will be easier to change the brake pipes if they haven't been done yet...
Just my 2p....!! Thumbs Up Pete
Post #442987 28th Jun 2017 9:19pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
The cost is adding up Sad
How does this one look https://www.ebay.co.uk/itm/142423538471
Post #443052 29th Jun 2017 2:03pm
mzplcg
This one's better. Covered in oil so will have less rust. Collection only but not a massive drive for you, Wing is near Aylesbury.
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...2423538471
Post #443054 29th Jun 2017 4:23pm
