![]() | Home > Technical (L322) > 2006 4.4 Petrol - Strange Fault Code - Can't find info |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Ah well. Non the wiser. Have booked it into the local LR Stealership on Monday for diagnostics. Will report back on what the Fault code means and it's resolution. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Unnecessary quote removed
Er... I don't know what the underlying problem is. That's what I ask for help and resolution with. All that I have is the diagnostic tool reporting this error:
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Looks more like an ECU/Computer problem than a car problem. Probably the fault needs clearing then watching to see if it comes back. If you are not "experiencing the fault" not sure whether this is one that has an effect? May prove a needless expensive trip to the stealers ..... |
@Joe90. Yes I have cleared it down three times and it immediately comes back. As does P0174 (Too lean bank 2). So it's going in to have both issues looked at really.
Ah, we are getting more of the issues now |
You think these error codes are related? The P0174 is quite intermittent but the B1B00 is constantly returning.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Don't fret too much about the engine light. Is yours LPG'd? That normally leads to a lean burn which can be adjusted by your lpg mech (if fitted). My lpg 4.4 V8 (BMW) runs all the time on lpg and never had an engine light on until a new lpg tech over-tweaked it.
No, not LPG'd. I thought it might be an injector issue. Tried some of that injector cleaner stuff in petrol tank. Didn't seem to resolve the P0174 error code.
You didn't mention that in your original post. |
Who does? |
OK, here's an update:
Further update: Confirmed (i've been under the car whilst it was raised on a ramp) that someone has quite recently cut the exhaust and welded smaller, aftermarket Cats in. One of these recent welds is cracked.
Class_5 Member Since: 01 Jan 2017 Location: Yateley Posts: 29 ![]() ![]() |
Hopefully not expensive to rectify.
