Home > Technical (L322) > 2006 4.4 Petrol - Strange Fault Code - Can't find info
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Can anyone throw some light on this fault code?
FEM-Navigation
B1B00-49 (2F) Electrically erasable programmable read only memory - bad checksum in flash - System internal failure - internal electronic failure.
Which bit has failed and what do I need to do to fix it please?
Post #443538 4th Jul 2017 7:23pm
Gyre8
Ah well. Non the wiser. Have booked it into the local LR Stealership on Monday for diagnostics. Will report back on what the Fault code means and it's resolution.
Post #443916 8th Jul 2017 2:18pm
steptoe
Re: 2006 4.4 Petrol - Strange Fault Code - Can't find info
Unnecessary quote removed
You've given us the fault code but you haven't said what the problem is or symptoms are ??
Post #444024 9th Jul 2017 12:25pm
Gyre8
Er... I don't know what the underlying problem is. That's what I ask for help and resolution with. All that I have is the diagnostic tool reporting this error:
FEM-Navigation
There are no overt symptoms that I can discern. That doesn't mean there aren't any, just that I'm not experienced enough to discern them.
Post #444039 9th Jul 2017 2:47pm
Looks more like an ECU/Computer problem than a car problem. Probably the fault needs clearing then watching to see if it comes back. If you are not "experiencing the fault" not sure whether this is one that has an effect? May prove a needless expensive trip to the stealers ..... Exclamation .
Post #444040 9th Jul 2017 4:08pm
Gyre8
@Joe90. Yes I have cleared it down three times and it immediately comes back. As does P0174 (Too lean bank 2). So it's going in to have both issues looked at really.
I just don't like driving around with the check engine light on. It makes me anxious. And one day it could be masking something more serious.
Post #444044 9th Jul 2017 4:36pm
Ah, we are getting more of the issues now Wink .
Post #444056 9th Jul 2017 6:25pm
Gyre8
You think these error codes are related? The P0174 is quite intermittent but the B1B00 is constantly returning.
Mind you, I'm learning that everything concerning the workings of FFRRs seems interrelated!
Post #444069 9th Jul 2017 8:20pm
Dolphinboy
Don't fret too much about the engine light. Is yours LPG'd? That normally leads to a lean burn which can be adjusted by your lpg mech (if fitted). My lpg 4.4 V8 (BMW) runs all the time on lpg and never had an engine light on until a new lpg tech over-tweaked it.
If you are just petrol, then it seems to point to something in the fuel delivery system, maybe a duff injector or summat?
Post #444074 9th Jul 2017 9:16pm
Gyre8
No, not LPG'd. I thought it might be an injector issue. Tried some of that injector cleaner stuff in petrol tank. Didn't seem to resolve the P0174 error code.
Anyway, it's in with local LR tomorrow, so hopefully it will be resolved.
Post #444084 9th Jul 2017 10:14pm
steptoe
Gyre8 wrote:
I just don't like driving around with the check engine light on. .
You didn't mention that in your original post.
Post #444136 10th Jul 2017 4:11pm
Gyre8
Who does?
Post #444137 10th Jul 2017 4:24pm
Gyre8
OK, here's an update:
LR Dealership have just said investigations are continuing, but they say that two new Catalytic Converters have recently been fitted but they are too small(?) and one has a crack in it. I asked how, if they were nearly new, how come one is cracked and the service desk guy said it may have happened during fitment (seemed a bit vague).
Don't understand the this as I don't know how/why anyone would fit (or be able to fit) incorrect (i.e. smaller) Cats.
The also said that one O2 sensor is showing a fault, but it may not be faulty(!).
Post #444142 10th Jul 2017 4:49pm
Gyre8
Further update: Confirmed (i've been under the car whilst it was raised on a ramp) that someone has quite recently cut the exhaust and welded smaller, aftermarket Cats in. One of these recent welds is cracked.
The standard exhaust pipe is about 3 inches diameter coming off the manifold and the welded in pipe Cat pipe-ends are about 2.25 inches, with correspondingly smaller Cats. Thus the exhaust gas outflow is restricted
This is going to get expensive to rectify!
I do wonder why both Cats were replaced? Do some thieving scrotes still steal Cats?
Post #444242 11th Jul 2017 6:12pm
Class_5
Hopefully not expensive to rectify.
I've got a 2004 V8 running 90% of the time on LPG, never had an engine management light come on until recently. Initial diagnosis showed that the post catalytic lambda sensors had failed. Decided to change all pre-cat & post cat lambdas, one was practically welded in place so that meant dropping down one of the {original) catalytic converters. When the cat was inspected it was clear that it had started to break up, so replacements were necessary.
New originals are a horrid price, so decided to go with Direnza stainless steel sports cats (much cheaper). They turned out to be really good quality and fitted OK. With the new cats and lambdas installed and fault codes cleared all was well for a few miles, then the engine management light came back on - this was partly expected as the sports cats are less restricted than standard cats, thus the post cat lambdas were throwing errors codes. Simple fix - installed some lambda spacers between the post cat lambdas and the cats (they cost a few quid and simply hold the tip of the sensors a bit away from the exhaust flow). Worked a treat and no more engine management light.
Hope this helps.
Post #444267 11th Jul 2017 8:14pm
