![]() | Home > Technical (L322) > Mysterious *clunk* when braking... |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Sounds like classic lower arms. What suspension work was done? 2007 Vogue TDV8 with 255/55/20's fitted |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
She had two new rear dampers and a ball joint. They said they could find nothing loose or amiss other than that..and to be fair, neither could the MOT guy! |
JPJ64 Member Since: 23 Jun 2017 Location: Newcastle upon Tyne Posts: 49 ![]() ![]() ![]() |
I had the same 'clunk' on mine. Diagnosed as a front drop link. Had both replaced and she's now as quiet as a 3.6V8 diesel mouse could ever be |
Got to admit that it sounds / feels like the issue is at the rear..but I have been wrong about such things before! |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
I have had this, "clunk when braking" twice on my car now, both times it has been the lower rear hub bushes.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Are the caliper bolts done up correctly. If it's clunking when braking, notably when changing direction it could be that. Ed |
Well the noise has disapoeared again niw the weather has dried up! Will try spraying the bushes and see if that makes a difference. Calipers were all checked by the garage.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I had the same noise on mine for 6 months, it was the lower arm at the front, but the one towards the rear.
