![]() | Home > General > 2004 TD6? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Gearbox
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Water ingress in the rear left side compartment.
There will be rusty brake pipes - front, rear and connecting (all hidden away under plastic covers) unless your friend has had them replaced .
sheep911uk Member Since: 09 May 2017 Location: Northampton Posts: 30 ![]() ![]() |
Will that have been picked up on previous Mot? |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
No. MOT testers only report on what they can see, they do not remove parts at all.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
But if the rest of the car looks sound, don't neccesarily let that put you off. The aren't a fortune to replace. There is nothing that can't be fixed with a hammer😜😜
Thanks all, I also need to weigh up the options between buying this with 77k and no gearbox work having been done or buying a higher mileage one which has had the gearbox replaced.
Diesels hate short trips, they are designed to be running all day long (hot) e.g. fairground generators.
Cheers not keen on petrol option. |
