Home > General > 2004 TD6?
sheep911uk
2004 TD6?
I am going to view a friends 2004 Td6 next week with 77k miles from new, anything to look out for or be aware of?
Thanks
Post #443867 7th Jul 2017 10:40pm
Dolphinboy
Gearbox
Steering wheel in and out motor
Bushes and suspension in general
Rust on arches/sub frame/rear door
Lots here in the wiki (top right of the site navigation under the FFRR logo)
Enjoy Thumbs Up
Post #443884 8th Jul 2017 9:09am
Water ingress in the rear left side compartment.
Do the sat nav, radio, cd player and tv work?
Service history and list of work done to the car.
Does the door locking work correctly, how many keys?
Does the air suspension lift and fall as it should?
Does the front blower fan change speed correctly?
Post #443885 8th Jul 2017 9:30am
There will be rusty brake pipes - front, rear and connecting (all hidden away under plastic covers) unless your friend has had them replaced .
Post #443898 8th Jul 2017 12:17pm
sheep911uk
Will that have been picked up on previous Mot?
Post #443901 8th Jul 2017 12:41pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
No. MOT testers only report on what they can see, they do not remove parts at all.
This is why you will see.....
"Under-trays fitted obscuring some underside components"
In the same way they won't check a seatbelt where a child seat is left in.
The brake pipes are probably rotten and hidden, they use the above advisory to cover their bottom. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #443983 8th Jul 2017 11:37pm
But if the rest of the car looks sound, don't neccesarily let that put you off. The aren't a fortune to replace. There is nothing that can't be fixed with a hammer😜😜
Post #444002 9th Jul 2017 9:02am
sheep911uk
Thanks all, I also need to weigh up the options between buying this with 77k and no gearbox work having been done or buying a higher mileage one which has had the gearbox replaced.
I do very little mileage as I work 4 miles from home so I might get lucky with the gearbox.
Post #444016 9th Jul 2017 11:22am
SKOT
Diesels hate short trips, they are designed to be running all day long (hot) e.g. fairground generators.
If you're doing 4 miles each way to work buy a petrol V8. Or go electric. Smile 2006 4.2 SC
Post #444017 9th Jul 2017 11:24am
sheep911uk
Cheers not keen on petrol option.
Post #444021 9th Jul 2017 11:58am
