Home > Technical (L322) > L322 Timing Chain, what to do. 4.4 M62
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
HP win7 pro
Post #444087 10th Jul 2017 2:46am
holidaychicken
That should be fine, have you downloaded the manual from the Wiki ?
http://www.fullfatrr.com/wiki/Main_Page
Post #444093 10th Jul 2017 8:56am
knares
yes, tried several times yesterday and several times today
it down loads but when i try to open different things in PDF it says "pdf failed to open"
it has lots of options and some things work, there is an option, when opened, tells you how to use a P4 laptop or some thing, that works, an other option gives you the land rover badge
i am lost
i couldn't get any ware until i down loaded win-zip and i am lost with that too
Post #444121 10th Jul 2017 1:53pm
knares
when winzip was free it was easy to use but now i have paid for it ?????????????
i chose to unzip to C:\users
Post #444123 10th Jul 2017 2:06pm
holidaychicken
i think windows 7 does it for me, i dont have winzip or anything else but i have used 7 zip in the past.
Have you tired the right click Extract All explained below?
https://support.microsoft.com/en-US/help/1...-zip-files
http://www.techradar.com/news/the-best-free-winzip-alternative
Are you using Adobe to open the PDF ?
The extract i posted is from the repair manual
Post #444164 10th Jul 2017 8:47pm
p38arover
Australia
Knares, I have a genuine RAVE CD.
If you don't have any luck with downloads, PM your postal address and I'll send you a copy.
Cheers Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #444172 11th Jul 2017 1:24am
knares
hi, thanks, will give it a couple more goes first
Post #444228 11th Jul 2017 3:40pm
knares
wayneg wrote:
If you look at the top of the page under the Blue fullfatrr.com logo you will see wiki in red font (RR wikipedia). Do yourself a big favour and read up as much as you can to get a good insight into your vehicle. Lots of invaluable info and remedies all in one place
Also lots of info on BMW forums on the engine and youtube is also a great resource.
this guy locks the crankshaft by putting the locating pin in the flywheel. Then undoes the crankshaft bolt. RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #462211 26th Dec 2017 1:15pm
holidaychicken
He must be bonkers , the starter ring is not made of strong stuff and the 5 mm diameter pin is a little on the small side.
Knowing what it took me to undo my crank bolt and also breaking a 3/4 bar doing it up to the correct torque, I definitely wouldn’t try it unless my life depended on it Smile
Post #462273 27th Dec 2017 2:24am
knares
how did you go Josho RR 2005 4.4 petrol
Post #463608 7th Jan 2018 11:23am
