Home > Technical (L322) > HELP FUEL PROBLEM
Dave
HELP FUEL PROBLEM
Having picked my car up on Saturday afternoon, where they changed the oil and fuel filter. I've driven the car for a couple of hours and she broke down. Shuddered to a stop. There's over half a tank of fuel in the car, The car wont start and sounds lumpy when it tries to. It just seems co-incidental that Hunters changed the fuel filter and now I have a fuel problem. Does any body have any advice on how to fault find and fix this., I did call Hunters, who just recommended I get it recovered to them so that they can look at it. I plugged the gap IID tool in, and there were many fuel rail system errors and sensor high temperatures. I cleared all the faults and even though the car wont start the faults don't reappear. Dave
2012 Vogue Westminster 4.4
Post #444279 11th Jul 2017 8:18pm
something might have been dislodged when they did the oil change...check under the bonnet for loose connections Dave, the battery ones in particular... ... - .- -.
Post #444299 12th Jul 2017 6:30am
Dave
I had a look thanks Stan, she tuns over no problem just wont fire up, well she does for a second then dies, i'll have another look in daylight today. Do they have a fuel cut off switch? Dave
Post #444300 12th Jul 2017 6:39am
Baltic Blue
The fuel metering valve acts as a fuel cut_off if 12v supply missing. Fuse??
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #444303 12th Jul 2017 6:53am
rar110
Air in the fuel line? Maybe the fuel filter isn't sealing properly. ______________________________
Post #444306 12th Jul 2017 7:28am
Dave
Got the car transported to Hunters LR this afternoon. I'll keep you posted.
I did talk to a friend (ex car mechanic) of mine who guessed that the car only had half a tank of fuel, he said the transfer pump in the tank may have gone as the shape of the tank is saddle shaped, i didn't think it was, but we'll see Dave
Post #444367 12th Jul 2017 5:48pm
rar110
Lift pump failure is a possibility. ______________________________
Post #444390 12th Jul 2017 8:03pm
Dave
Got a call today, they say the low-pressure fuel pump had packed up, looking at the manual I guess that means the secondary fuel pump, that's next to the fuel filter, the cost to fix is £400. I've told them to look after the car as I'll be abroad for the next few months Dave
Post #444592 14th Jul 2017 6:26pm
