![]() | Home > Technical (L322) > HELP FUEL PROBLEM |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 ![]() ![]() ![]() |
Having picked my car up on Saturday afternoon, where they changed the oil and fuel filter. I've driven the car for a couple of hours and she broke down. Shuddered to a stop. There's over half a tank of fuel in the car, The car wont start and sounds lumpy when it tries to. It just seems co-incidental that Hunters changed the fuel filter and now I have a fuel problem. Does any body have any advice on how to fault find and fix this., I did call Hunters, who just recommended I get it recovered to them so that they can look at it. I plugged the gap IID tool in, and there were many fuel rail system errors and sensor high temperatures. I cleared all the faults and even though the car wont start the faults don't reappear. Dave
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
something might have been dislodged when they did the oil change...check under the bonnet for loose connections Dave, the battery ones in particular... ... - .- -.
I had a look thanks Stan, she tuns over no problem just wont fire up, well she does for a second then dies, i'll have another look in daylight today. Do they have a fuel cut off switch? Dave
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
The fuel metering valve acts as a fuel cut_off if 12v supply missing. Fuse??
Got the car transported to Hunters LR this afternoon. I'll keep you posted.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Lift pump failure is a possibility. ______________________________
Got a call today, they say the low-pressure fuel pump had packed up, looking at the manual I guess that means the secondary fuel pump, that's next to the fuel filter, the cost to fix is £400. I've told them to look after the car as I'll be abroad for the next few months Dave
