![]() | Home > Technical (L322) > 4.4 tdV8 Oil filter removal. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
Does anyone know the size of the nut on the oil filter ??
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 840 ![]() ![]() |
Does anybody know where the oil filter is on the engine? |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
yeah its fairly easy but the joy is short lived when you need to access the drain plug at the bottom.. Although not ideal (as the oil goes everywhere) if you put a plastic sheet or in my case I had some Ikea left over cardboard which caught the oil spill.. I then use the brake cleaner spray to remove the oil from the sub frame.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
BB it is 36mm, I am using this
Thanks Nino,
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
With tools you always get what you paid for. I suspect £3.00 for a socket that big is not going to be a quality product!.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
its designed to have the oil sucked out, I know that the pop on oil drain tube is a convenient place to drain it and if you haven't got suction then thats the best plan, but there is no difference if you suck it out on this engine as the other end of the pop on tube is the suction point so it drains it from the same place!
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Certainly worth not skimping if you use them often enough and have a big impact hammer like moi. Used one cheap socket once and simply peeled apart like a banana. Ed |
I have ordered one from Eurocar parts.
