Home > Technical (L322) > 4.4 tdV8 Oil filter removal.
Baltic Blue
Does anyone know the size of the nut on the oil filter ??
Would this fit? 36mm.?
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #445327 22nd Jul 2017 11:09am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Does anybody know where the oil filter is on the engine?
Post #445332 22nd Jul 2017 11:52am
Baltic Blue
1, 2 and 3 in diagram.
Post #445333 22nd Jul 2017 11:58am
GGDR
Is that bang on top of the engine? Am I seeing that correctly?
Wow that could make for the easiest oil change ever...
. Cheers, Greg
Post #445337 22nd Jul 2017 1:16pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
yeah its fairly easy but the joy is short lived when you need to access the drain plug at the bottom.. Although not ideal (as the oil goes everywhere) if you put a plastic sheet or in my case I had some Ikea left over cardboard which caught the oil spill.. I then use the brake cleaner spray to remove the oil from the sub frame.
PS £7.99 for a 36mm socket a farce. Even with ECP 30% code it would be still dearer as I paid £2.15 at my local store. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #445341 22nd Jul 2017 1:40pm
nino_nino
BB it is 36mm, I am using this
Post #445359 22nd Jul 2017 4:05pm
Baltic Blue
Thanks Nino,
My adjustable is just not quite big enough. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #445363 22nd Jul 2017 4:16pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
With tools you always get what you paid for. I suspect £3.00 for a socket that big is not going to be a quality product!.
Don't over -tighten either - ( I know you have the WSM so no excuses my friend!! Whistle ) Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #445374 22nd Jul 2017 5:07pm
its designed to have the oil sucked out, I know that the pop on oil drain tube is a convenient place to drain it and if you haven't got suction then thats the best plan, but there is no difference if you suck it out on this engine as the other end of the pop on tube is the suction point so it drains it from the same place!
I just have to make an adapter for mine....... There is nothing that can't be fixed with a hammer😜😜
Post #445377 22nd Jul 2017 5:40pm
sako243
Certainly worth not skimping if you use them often enough and have a big impact hammer like moi. Used one cheap socket once and simply peeled apart like a banana. Ed
Post #445382 22nd Jul 2017 6:35pm
Baltic Blue
I have ordered one from Eurocar parts.
Post #445431 23rd Jul 2017 8:05am
