![]() | Home > Maintenance & Mods (L322) > Help oily substance on fuse box |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837
leaky fuel pipe maybe , its in that area.. ... - .- -.
| andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 104
I will have to see if it smells of diesel it could be do you have to take all the boot panels out to get to it ? |
Stan take it I will have to take out all the boot panels to see the pipes |
not sure..you might be able to see via the access panel.. ... - .- -.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428
Looks like most things accessed by removing rear wheel arch liner, and / or tank cover (but this one too low to cause a leak in the cubby) .
Just looking at the rubber around the fuel filler cap and it looks perished wonder if it's when I filled up ? Could have dropped into the inside and on the fuse box ,anybody know if they are replaceable or how they come off ?? |
Unnecessary quote removed
RAVE is pretty vague about removing the filler neck, unless I am not searching hard enough.
Thanks joe looks like a day of stripping and see if I can get it sorted seam to be spending more time mending it than driving at the moment |
Just a quick update stripped the entire boot out to see if I could see any leaks from the fuel filler and I couldn't see a thing but took the fuse box out cleaned and dried it out and put back together but I did notice that the seal around the filler was cracked and the fuel cap isn't a good tight fit so ordered a new one from guy salmon Wakefield so pick it up tomorrow and try that,also unblocked both the sunroof drains at the back and front |
