Home > Maintenance & Mods (L322) > Help oily substance on fuse box
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Help needed !!! Bit of a strange one but in the drivers side rear compartment where the fuse box is I have noticed a oily substance all over the fuse box could it be the shocker that is leaking? Or has anybody had this before I did clean it down but having a ride out to Skegness I have noticed it again any help would be great fully recived Yawn
Post #446058 28th Jul 2017 8:42pm
leaky fuel pipe maybe , its in that area.. ... - .- -.
Post #446061 28th Jul 2017 9:06pm
andyfid
I will have to see if it smells of diesel it could be do you have to take all the boot panels out to get to it ?
Post #446063 28th Jul 2017 9:10pm
andyfid
Stan take it I will have to take out all the boot panels to see the pipes
Post #446326 1st Aug 2017 4:23pm
not sure..you might be able to see via the access panel.. ... - .- -.
Post #446327 1st Aug 2017 4:28pm
Looks like most things accessed by removing rear wheel arch liner, and / or tank cover (but this one too low to cause a leak in the cubby) .
Post #446334 1st Aug 2017 5:19pm
andyfid
Just looking at the rubber around the fuel filler cap and it looks perished wonder if it's when I filled up ? Could have dropped into the inside and on the fuse box ,anybody know if they are replaceable or how they come off ??
Post #446340 1st Aug 2017 5:40pm
andyfid
Unnecessary quote removed
you any ideas Joe what it could be going to strip the complete boot out tomorrow see if I can see anything
Post #446359 1st Aug 2017 8:03pm
RAVE is pretty vague about removing the filler neck, unless I am not searching hard enough.
My guess is a bit of both, access from inside the cubby (but possibly a lot of kit will need to come out!), but also from below, after removing the wheelarch liner, my preference would be the latter, though. Not had this part of the car off, so can't say for certain. .
Post #446373 1st Aug 2017 10:04pm
andyfid
Thanks joe looks like a day of stripping and see if I can get it sorted seam to be spending more time mending it than driving at the moment Big Cry
Post #446375 1st Aug 2017 10:19pm
andyfid
Just a quick update stripped the entire boot out to see if I could see any leaks from the fuel filler and I couldn't see a thing but took the fuse box out cleaned and dried it out and put back together but I did notice that the seal around the filler was cracked and the fuel cap isn't a good tight fit so ordered a new one from guy salmon Wakefield so pick it up tomorrow and try that,also unblocked both the sunroof drains at the back and front
Post #446444 2nd Aug 2017 6:50pm
