Home > Technical (L322) > Dead or faint pixels |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1662 |
Hi All,
5th Jan 2011 1:17pm |
It has been suggested that just by spraying electrical contact cleaner in where the ribbon cable connects then this solves the prob in 50% of cases. It cleans out the furring between the contacts caused by moisture.
5th Jan 2011 1:46pm |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
dan, good advice as always- is it a fairly straight forward job to remove the binnacle and clean the contacts? |
5th Jan 2011 2:48pm |
Thanks Dan (again..!)
5th Jan 2011 2:50pm |
I've heard it's not too difficult, but not done the job myself. I think one has to remove the end cap off the dash (the bit that holds the vent & light switches) then undo the dash top (easy). I'd guess at about 30-45 minutes of removal and 20 mins of re-assembly. Not sure what the WSM suggests for the bincacle... Dan |
5th Jan 2011 2:52pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Can you get to this ribbon without doing that drilling bit i have seen on one guide?
5th Jan 2011 3:36pm |
FYI - Dan your talking to the converted with me. Always on 24x7x365..! Ash
5th Jan 2011 4:00pm |
Dont know, sorry.
Nope, it cycles on and off every minute or so. Also do you leave the Auto-Recirc on? buttons by d86cfv, on Flickr |
5th Jan 2011 4:12pm |
not necessarily no, are you going to tell me to leave that on too? 2004 black Vogue TD6 |
5th Jan 2011 5:00pm |
What does auto recirc actually do... I don't leave that one on. I assume it intermittently recirc air from inside the cabin as opposed to always using outside (cleaned/dehumidified) air in..?
5th Jan 2011 5:28pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
With the recerc on auto the car draws it's air from the out side until it detects politants at which point it closes and draws air from within the car , I have always set mine to auto and I never seam to smell any bus or lorry fumes when I'm in Trafic . 2008 MY Supercharged
5th Jan 2011 5:59pm |
As per Axle, a sensor at the front of the car is contently sampling the air you're driving through. As soon as it detects a pollutant in the air - either from a car/lorry in front or from a drain or pig farm then it closes the flaps and recircs the air until the pollutant/smell goes away.
5th Jan 2011 6:20pm |
Cool - Mines now set to auto anyway..! Ash
5th Jan 2011 8:57pm |
