![]() | Home > Technical (L322) > Dead or faint pixels |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi All,
It has been suggested that just by spraying electrical contact cleaner in where the ribbon cable connects then this solves the prob in 50% of cases. It cleans out the furring between the contacts caused by moisture.
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 ![]() ![]() ![]() |
dan, good advice as always- is it a fairly straight forward job to remove the binnacle and clean the contacts? |
Thanks Dan (again..!)
I've heard it's not too difficult, but not done the job myself. I think one has to remove the end cap off the dash (the bit that holds the vent & light switches) then undo the dash top (easy). I'd guess at about 30-45 minutes of removal and 20 mins of re-assembly. Not sure what the WSM suggests for the bincacle... Dan ![]() |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Can you get to this ribbon without doing that drilling bit i have seen on one guide?
FYI - Dan your talking to the converted with me. Always on 24x7x365..! Ash
Dont know, sorry.
Nope, it cycles on and off every minute or so. Also do you leave the Auto-Recirc on? ![]() buttons by d86cfv, on Flickr ![]() |
not necessarily no, are you going to tell me to leave that on too? 2004 black Vogue TD6 |
What does auto recirc actually do... I don't leave that one on. I assume it intermittently recirc air from inside the cabin as opposed to always using outside (cleaned/dehumidified) air in..?
With the recerc on auto the car draws it's air from the out side until it detects politants at which point it closes and draws air from within the car , I have always set mine to auto and I never seam to smell any bus or lorry fumes when I'm in Trafic . 2008 MY Supercharged
As per Axle, a sensor at the front of the car is contently sampling the air you're driving through. As soon as it detects a pollutant in the air - either from a car/lorry in front or from a drain or pig farm then it closes the flaps and recircs the air until the pollutant/smell goes away.
Cool - Mines now set to auto anyway..! Ash
