Home > Technical (L322) > air suspension reset ?
Page 1 of 3 123>
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
am I reading this right , that if you do any suspension related work on an L322 you have to reset the air suspension via diag computer ? the car I pick up tomorrow has not long since had the front anti roll bar replaced and im wondering if the garage did it in the correct manner
Post #446995 7th Aug 2017 8:23pm
Suggest you wait and see if you have any faults, and if the air suspension is inactive .
Post #446997 7th Aug 2017 8:35pm
bembo449
sorry joe , im just itching to get started on it lol
Post #447002 7th Aug 2017 8:41pm
It is actually fairly straight forward - if it is working and not throwing a bong: "AIR SUSP INACTIVE"" then you should be OK
There are other fault messages! .
Post #447012 7th Aug 2017 10:27pm
bembo449
Im taking my scan tool to check for codes so see what it comes up with but thanks for that useful info as i didnt know a bong along with the display warning was important , hoping it does bong now lol
Post #447014 7th Aug 2017 10:31pm
bembo449
right folks , collected the car this morning , the front end is in the low position , "air susp inactive" came up on the dash once he started it up but it didn't Bong at all , its laggin down here so no going to be able to get codes read till tomorrow morning
Post #447053 8th Aug 2017 12:52pm
bembo449
Right codes read on solus ,
100 AV fault
107 front left height sensor
50 can bus fault
Looks like i need a height sensor ?
After clearing codes the light on the sus toggle is now lit but obvs doesnt do anything , just flashes , compressor is at 6.7bar , is that a good thing ?
Post #447188 9th Aug 2017 9:32am
alistairh
The 6 bar reading is the resovoir. Far too low.could be the compressor itself plus the height sensor
Post #447190 9th Aug 2017 10:03am
The air suspension won't adjust if any door is open Wink Thumbs Up
Post #447191 9th Aug 2017 10:07am
bembo449
Ok , well i reset everything and now getting air susp inactive max 35mph thos the comp kicks in on the first position on ignition
Post #447192 9th Aug 2017 10:18am
bembo449
going to keep posting info up folks as I feel im finding more things now im getting a proper look at it , well the battery the previous owner had put on was no where near the right spec , it was only 71AH and 650amp , luckily I have a good bosch battery that's 90AH and 850amp so will fit that tomorrow and start again , purchased a front height sensor so will fit that aswell and see what occurs , if I get to the point where a new compressor is required I may just stick onto springs and save future failings as it appears that this system is rarely totally reliable
Post #447211 9th Aug 2017 12:54pm
Clivefog
There is a replacement pump piston ring available. Cured my problems can't remember the seller on ebay, he is referenced on here a fair bit though not recently.
Post #447218 9th Aug 2017 1:43pm
Weegie
Bagpiping Andy.
http://bagpipingandy.com/ John
GAP iiD BT-Sold
Post #447220 9th Aug 2017 2:11pm
bembo449
good news , will see what tomorrow brings , I guess a pump refurb isn't going to break the bank lol
Post #447222 9th Aug 2017 2:30pm
bembo449
ive ordered a refurb kit from andy ,
Post #447225 9th Aug 2017 3:02pm
Page 1 of 3 123>
