|  | Home > Technical (L322) > air suspension reset ? |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Suggest you wait and see if you have any faults, and if the air suspension is inactive .
|  7th Aug 2017 7:35pm |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | sorry joe , im just itching to get started on it lol | ||
|  7th Aug 2017 7:41pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | It is actually fairly straight forward - if it is working and not throwing a bong: "AIR SUSP INACTIVE"" then you should be OK
|  7th Aug 2017 9:27pm |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | Im taking my scan tool to check for codes so see what it comes up with but thanks for that useful info as i didnt know a bong along with the display warning was important , hoping it does bong now lol | ||
|  7th Aug 2017 9:31pm |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | right folks , collected the car this morning , the front end is in the low position , "air susp inactive" came up on the dash once he started it up but it didn't Bong at all , its laggin down here so no going to be able to get codes read till tomorrow morning | ||
|  8th Aug 2017 11:52am |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | Right codes read on solus ,
|  9th Aug 2017 8:32am |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | The 6 bar reading is the resovoir. Far too low.could be the compressor itself plus the height sensor | ||
|  9th Aug 2017 9:03am |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | The air suspension won't adjust if any door is open  | ||
|  9th Aug 2017 9:07am |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | Ok , well i reset everything and now getting air susp inactive max 35mph thos the comp kicks in on the first position on ignition | ||
|  9th Aug 2017 9:18am |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | going to keep posting info up folks as I feel im finding more things now im getting a proper look at it , well the battery the previous owner had put on was no where near the right spec , it was only 71AH and 650amp , luckily I have a good bosch battery that's 90AH and 850amp so will fit that tomorrow and start again , purchased a front height sensor so will fit that aswell and see what occurs , if I get to the point where a new compressor is required I may just stick onto springs and save future failings as it appears that this system is rarely totally reliable | ||
|  9th Aug 2017 11:54am |
| Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354      | There is a replacement pump piston ring available. Cured my problems can't remember the seller on ebay, he is referenced on here a fair bit though not recently. | ||
|  9th Aug 2017 12:43pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276      | Bagpiping Andy.
|  9th Aug 2017 1:11pm |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | good news , will see what tomorrow brings , I guess a pump refurb isn't going to break the bank lol | ||
|  9th Aug 2017 1:30pm |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | ive ordered a refurb kit from andy , | ||
|  9th Aug 2017 2:02pm |
| Posting Rules
