![]() | Home > Technical (L322) > air suspension reset ? |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I don't think so, I don't think the values of the sensor actually mean anything.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
Ok pal , its pointing out ward toward the tyres |
Yeah that's the right way!
Maybe they arent leaking then, could be the height sensors.
Its got read out for each sensor , thats how i noticed the new sensor was reading minus , yours was obvious at least pal |
Update , got thoroughly hacked off so went to see a guy whos known to be excellent with landrovers ,30 mins and 20 quid later i have a CAN fault , he tested all the mechanicals and everything is spot on , oddly the car has behaved perfectly since he plugged into it , very strange |
david lanceley Member Since: 24 Jan 2013 Location: UK Posts: 6 ![]() ![]() |
I recently fitted one of Andy's kits. Couple of hours straightforward work and transformation of the air suspension. Now goes up and down as it should |
hi dave , yeah I refurbed the pump yesterday too , it seems to have perked the pump up as its gain over 2 bar in pressure so well worth the money and the few mins it took to do |
update , the guy who did my diag this morning emailed the graphs he took to some experts in Canada , they reckon my car is stuck in transportation mode which is a form of lower ride height than standard , this also means there is a BCM fault which may be an expensive repair , im going back asap for him to do some more testing to see wether that's the case |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
If it's in transport mode then it can be taken out again. Mine was in transport mode I took it out and it took less than 2 minutes overall. ______________________________
I hope that's the case pal , will see when I go back but it drives well as it is so aslong as it stays at its current ride height im happy |
