Home > Technical (L322) > air suspension reset ?
Page 3 of 3 <123
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I don't think so, I don't think the values of the sensor actually mean anything.
Not to make you sound stupid as it's easily done, but is the arm facing towards the wheel?
Post #447471 11th Aug 2017 10:04am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Ok pal , its pointing out ward toward the tyres
Post #447472 11th Aug 2017 10:06am
Stacker
Yeah that's the right way!
The articulation validity fault if I remember correctly means the height is constantly changing when it should be static, it's the fault I had when my front bags were leaking!
Post #447473 11th Aug 2017 10:07am
bembo449
Ok , thats summat then pal , ive soaped down all 4 bags this morning and all see ok ? I dont like the condition of the rear height sensors
Post #447474 11th Aug 2017 10:11am
Stacker
Maybe they arent leaking then, could be the height sensors.
Does your solus make a graph of height sensor values? That's what my mate did on his to check the height sensors to make sure the graph values all moved relatively.
When mine was leaking to be fair, you should hear it and put your finger on where the bag was leaking air from!
Post #447476 11th Aug 2017 10:13am
bembo449
Its got read out for each sensor , thats how i noticed the new sensor was reading minus , yours was obvious at least pal
Post #447477 11th Aug 2017 10:17am
bembo449
Update , got thoroughly hacked off so went to see a guy whos known to be excellent with landrovers ,30 mins and 20 quid later i have a CAN fault , he tested all the mechanicals and everything is spot on , oddly the car has behaved perfectly since he plugged into it , very strange
Post #447494 11th Aug 2017 12:55pm
david lanceley
2004 Range Rover Vogue Td6 Santorini Black
I recently fitted one of Andy's kits. Couple of hours straightforward work and transformation of the air suspension. Now goes up and down as it should
Post #447498 11th Aug 2017 1:48pm
bembo449
hi dave , yeah I refurbed the pump yesterday too , it seems to have perked the pump up as its gain over 2 bar in pressure so well worth the money and the few mins it took to do
Post #447548 11th Aug 2017 8:30pm
bembo449
update , the guy who did my diag this morning emailed the graphs he took to some experts in Canada , they reckon my car is stuck in transportation mode which is a form of lower ride height than standard , this also means there is a BCM fault which may be an expensive repair , im going back asap for him to do some more testing to see wether that's the case
Post #447549 11th Aug 2017 8:34pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
If it's in transport mode then it can be taken out again. Mine was in transport mode I took it out and it took less than 2 minutes overall. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #447550 11th Aug 2017 8:36pm
bembo449
I hope that's the case pal , will see when I go back but it drives well as it is so aslong as it stays at its current ride height im happy
Post #447551 11th Aug 2017 8:38pm
Page 3 of 3 <123
