![]() | Home > Technical (L322) > detachable towbar Q? |
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 ![]() ![]() ![]() |
To my knowledge, you can get two different types.
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
This may be a silly question ,but are you sure it's actually missing?
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
your right steve it was a silly question pal |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479 ![]() ![]() ![]() |
The 'flange' towbar (aka farmers hitch) is just over £120 from P F Jones.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
I think the farmers hitch is better cause I can put bikes on it as well as tow the caravan, when I'm not towing the blanking plug is fitted and the hitch is in the garage. Current: TDV8 (3.6) RRS HSE
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 ![]() ![]() ![]() |
I have the heavy pin and ball plus steps tow hitch that came off my 110 originally and was then used on a Disco.
This is the heavy duty "farmers hitch" it fits straight on to the FF if you remove the female receiver for the removable hitch.
Another advantage of the farmers flange |
Very true, I've got mine on the bottom holes to keep my plastic palace level. Current: TDV8 (3.6) RRS HSE
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
I had 3 different tow balls on my L322- and my favourite was an early flange/farmers hitch - as they had a smooth hole and I had a pin rather than a bolt.
Another vote for the farmer's version. Height adjustable, can carry a bike rack and tow at the same time. You can fit the ALKO tow balls if you want to which gives a bit more clearance from bumper to ball. The genuine one has 2 sets of holes, aftermarket has 3 and it a bit bigger. No need to remove it as a FFRR is meant for towing and doesn't look wrong with the towbar left in place. |
Druboo Member Since: 04 Jun 2017 Location: Wiltshire Posts: 12 ![]() ![]() ![]() |
Just tagging on to this subject.
Try tagging onto this thread |
Thank you Alistair
