Home > Technical (L322) > detachable towbar Q?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
my 322 has a full LR tow bracket and lectrics fitted ( dated 2002) from new but it hasn't seen a lot of use by the looks of it , the detachable swan neck is missing , is there only one type for the factory tow kit ?
Post #447541 11th Aug 2017 7:09pm
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
To my knowledge, you can get two different types.
There is the swan neck, and there is also a drop plate.
If you want the swan neck, you can either get the westfalia version, or the britpart one. The two parts are identical, and are both made by westfalia
Post #447557 11th Aug 2017 9:46pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
This may be a silly question ,but are you sure it's actually missing?
There is dedicated storage for the detachable swan neck and its keys under a flap in the floor of the boot at the right hand side - just below the removable panel for fuses etc on the right. You wouldn't be the first not to have realised it was there. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #447561 11th Aug 2017 11:09pm
bembo449
your right steve it was a silly question pal Laughing Wink , I had a good look for it before posting up my Q , the ccouple I got the car off didn't tow anything so wernt concerned that it didn't have one with it , anyway looks like I will be stumping up for one as it appears they are made of gold Shocked Crying or Very sad Confused
Post #447569 12th Aug 2017 5:31am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
The 'flange' towbar (aka farmers hitch) is just over £120 from P F Jones.
They sometimes come up on eBay for less. (Although someone is selling one at the moment on there which isn't actually the tow bar but is one of the bits which is removed when the armature is fitted, so don't be tempted by the £60 price!).
Post #447571 12th Aug 2017 7:28am
stu
I think the farmers hitch is better cause I can put bikes on it as well as tow the caravan, when I'm not towing the blanking plug is fitted and the hitch is in the garage. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447586 12th Aug 2017 11:02am
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
I have the heavy pin and ball plus steps tow hitch that came off my 110 originally and was then used on a Disco.
My 54-reg TD6 has a detachable ball. Will I have to replace the whole towing assembly from under the back, or is there somewhere the whole unit splits so that I can get it to end in a plate to bolt the proper tow hitch to.
So many questions, so little time...........
Post #447597 12th Aug 2017 12:31pm
stu
This is the heavy duty "farmers hitch" it fits straight on to the FF if you remove the female receiver for the removable hitch.
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447598 12th Aug 2017 12:57pm
chris_read
Another advantage of the farmers flange Shocked is that you can adjust the height if necessary Thumbs Up
Post #447602 12th Aug 2017 1:10pm
stu
Very true, I've got mine on the bottom holes to keep my plastic palace level. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447611 12th Aug 2017 3:15pm
I had 3 different tow balls on my L322- and my favourite was an early flange/farmers hitch - as they had a smooth hole and I had a pin rather than a bolt.
Later ones were half threaded and required a bolt - which took an age to remove,
IMHO the 'removeable' hitch left too much in place vs the amount that was removable.
Post #447618 12th Aug 2017 6:09pm
mzplcg
Another vote for the farmer's version. Height adjustable, can carry a bike rack and tow at the same time. You can fit the ALKO tow balls if you want to which gives a bit more clearance from bumper to ball. The genuine one has 2 sets of holes, aftermarket has 3 and it a bit bigger. No need to remove it as a FFRR is meant for towing and doesn't look wrong with the towbar left in place. Thumbs Up
Post #447633 12th Aug 2017 6:50pm
Druboo
England 2005 Range Rover Vogue Td6 Zambezi Silver
Just tagging on to this subject.
I've got a westfalia removable towbar fitted. To remove is it supposed to be a case of unlock with the key, turn the knob to the green and the ball drops out? Mine doesn't want to play Confused
Post #447637 12th Aug 2017 7:37pm
Try tagging onto this thread Very Happy
Post #447640 12th Aug 2017 7:51pm
Druboo
Thank you Alistair
Twist and pull and it's off Smile
Post #447642 12th Aug 2017 8:00pm
