![]() | Home > Technical (L322) > 4.4 TDV8 Cracked air intake manifold |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
this should help....
sekrap Member Since: 25 Jun 2017 Location: Rutland Posts: 8 ![]() ![]() ![]() |
The first picture shows where the crack is. Everything else looks fine. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
As Stan says..welcome!!
Thanks Stu. It's got 74k on the clock. How pricey are the replacement part |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Which part has split ?
It's 11 |
No. 11 is called :-
Thanks for your help Stu, is this a diy fix or more a garage job. Between myself and my son we can do a lot of jobs on cars |
Well if you're confident competent diy ers I'd go for it! At the end of the day it's just nut and bolt work!
Thanks again. I'll let you know how I get on |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
BB where do you get all this nice pictures? |
Nino,
Found them |
Nino,
