Home > Technical (L322) > 4.4 TDV8 Cracked air intake manifold
Page 1 of 3 123>
Mikeyp
Hi,
Apologies my first post is a cry for help. Im posting on behalf of my dad as I'm "quicker' on the computer Laughing
My dads RR 2011 4.4 TDV8 went into 'restricted performance' on the way home today and after investigating under the bonnet and removing the engine cover it was apparent that a manifold had cracked. It had blown out some oil and lifted the engine cover.
Im assuming the 'donut' shaped manifold on top of the engine is the plenum chamber with four hoses coming from it.
The N/S manifold that connects to this part via the front pipe has cracked at the seam. Can anyone helped to identify the exact name of this part please as internet searches are proving fruitless.
Many thanks
Mike
Post #447635 12th Aug 2017 7:02pm
this should help....
http://www.fullfatrr.com/forum/post444731.html#444731
welcome to the forum... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #447636 12th Aug 2017 7:15pm
sekrap
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
The first picture shows where the crack is. Everything else looks fine.
Post #447638 12th Aug 2017 7:39pm
stu
As Stan says..welcome!!
Can I ask how many miles are on your FF please? Just curious, I've recently had one of the inlet rubbers split giving the same restricted performance message.
If you are going to do the work yourself it's just basic tools apart from the three tiny torx screws at the front. The two engine cover mounts are screwed onto two of them. Screw one of the cover mounts off and make sure you have the right size before you start or like me you'll kick yourself. Sorry can't remember the size, but it's tiny. Hope you get sorted soon. Let us know how it goes.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447639 12th Aug 2017 7:50pm
sekrap
Thanks Stu. It's got 74k on the clock. How pricey are the replacement part
Post #447641 12th Aug 2017 7:59pm
Baltic Blue
Which part has split ?
No. 9, or No. 11 ?
The 4 short rubber hoses look to have been changed because they are the new more rigid type. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447644 12th Aug 2017 8:14pm
sekrap
It's 11
Post #447645 12th Aug 2017 8:17pm
Baltic Blue
No. 11 is called :-
Left hand cylinder bank air intake manifold.
Ask Dan to quote a price and please post part number. etc. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447646 12th Aug 2017 8:22pm
sekrap
Thanks for your help Stu, is this a diy fix or more a garage job. Between myself and my son we can do a lot of jobs on cars
Post #447650 12th Aug 2017 8:25pm
stu
Well if you're confident competent diy ers I'd go for it! At the end of the day it's just nut and bolt work!
Thanks for pictures BB.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447652 12th Aug 2017 8:32pm
sekrap
Thanks again. I'll let you know how I get on
Post #447653 12th Aug 2017 8:34pm
nino_nino
BB where do you get all this nice pictures? Smile
Post #447656 12th Aug 2017 9:11pm
Baltic Blue
Nino,
I took a screenshot from the relevant WM section.
I recon that in the last 2 years 90% of all 4.4tdv8 problems reported by members can be seen on that picture.
Either splits in the rubber hoses or in the plastic manifolds, or the air changeover valve stuck.!!!
I have had 2 out of the 3. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447675 13th Aug 2017 7:54am
nino_nino
Found them Smile , under locations in WM Thumbs Up .
knock on wood 0 of 3. Very Happy
Post #447684 13th Aug 2017 9:09am
Baltic Blue
Nino,
0 / 3 ,
I think you need to hug a tree 😁😁 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447699 13th Aug 2017 11:31am
Page 1 of 3 123>
