Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005
Page 7 of 12 <123 ... 678 ... 101112>
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Just returned from a 700 mile trip with no measurable loss of coolant through the pinhole in my radiator vs the usual 8oz loss. So the lower temp does seem to stress the system less. Don't see any change in gas mileage (petrol mileage).
Post #440046 30th May 2017 2:07am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
do you just leave the sender unit in the housing, the housing he replaced didnt seem to have a sender unit in it
Post #442441 23rd Jun 2017 4:20pm
There is no sender unit, there is a control for the thermostat which is no longer used when a "normal" thermostat is fitted... The plug housing stays in the old modified thermostat housing but you should disconnect the plug in case it starts leaking... Thumbs Up Pete
Post #442453 23rd Jun 2017 6:03pm
doclees
FYI mine is throwing a check engine light with either the Electric thermostat circuit fault or the Stuck thermostat fault code being the issue. So I guess it's time to order the 10 ohm 100w resistor.
Post #443298 2nd Jul 2017 3:16pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I've had the thermostat mod fitted for 10 months and have had the electric thermostat fault for that entire time but it has never thrown up the check engine light. Can I suggest you check your fault codes again as I know that the thermostat fault does not activate the check engine light... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #443332 2nd Jul 2017 8:07pm
doclees
2 codes as above. Not sure which one gives the check engine light but it is one. Instructions from mod manufacturer has the recommendation for the 10 ohm 100 watt fix. Thought it was my Lambda fault but no. Some do it some don't.
Post #443418 3rd Jul 2017 7:22pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Have just ordered the kit and eager to get the mod done.
But I am a bit confused - can you use this housing OEM NUMBER 11531720173 instead of cutting down and filing down?
Post #444447 13th Jul 2017 11:19am
doclees
No wrong housing. No quick connect for the hose. The cutting is easy. I used pliers to depress the thermostat spring and removed the guts first so things don't go flying.
Post #444475 13th Jul 2017 4:09pm
doclees
This is irritating. I installed the 10 ohm 100 w resistor as per the modification thermostat instructions but still getting the 2 fault codes of which one of them is giving me a service engine soon light. 0x48c and 0x48B . Anyone have a suggestion?
Post #444863 18th Jul 2017 1:34am
doclees
OK a side question with the mod. Is there any evidence this improves the life of the valley pan gasket?
Post #448278 18th Aug 2017 2:57pm
Anything that reduces engine temp has to be good for all aspects of the engine, including gaskets...
But "evidence"..... NO.... Pete
Post #448303 18th Aug 2017 5:31pm
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
Just replaced my stat with a 88C one.
£43 and a little over a hour, and 30 minutes of that was undoing one bolt. Those who have done this job will know which one I mean Censored Not Galway but Balmoral green actually
148,000 miles
Post #448561 21st Aug 2017 1:43pm
3/8 drive, deep socket fits perfectly, takes about 20seconds....!!! Pete
Post #448577 21st Aug 2017 4:14pm
kanikune
Finland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Did this thermostat swap week ago. Been great so far. Getting the air out worked really well. Got the bleeding screw Off and poured new coolant in really slowly. Pumped coolant line connecting to thermostat couple of times in the end.
After test run could only add very small amount of coolant.
Post #460226 10th Dec 2017 4:27pm
ohuntsman
Went to do this mod today and the OEM thermostat that I had fitted has a a central column that wouldn't allow the kit to fit into the housing Censored
Had to buy another with had the same central column!!!!
Has anyone else had this issue?
Post #461740 21st Dec 2017 11:20pm
