![]() | Home > Technical (L322) > Oil Leak - Further Info please. |
MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25 ![]() ![]() ![]() |
The o rings fail and let oil weep through- the leak will only get worse the longer you leave it. The o rings are only about 30p each x 2 and the repair takes around half a hour. |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Hi,
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
OK, Thanks both. Yes, LR have quoted me £848 to repair the leak - 5 x hours labour. If they have to remove the gearbox, will they have to change the gearbox oil in it?
MRx4 Member Since: 22 Oct 2016 Location: Madrid Posts: 55 ![]() ![]() |
I found this, after five days parked |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Not sure which engine you have there. It looks to me like ZF6 transmission fluid, which will probably be the O rings on the electrical sleeve.
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
In garage talk the "rear main" is the seal at the rear of the crankshaft where it comes out the back of the engine. On some engines it's just a round seal that's removed and a new one knocked in, on others it's a sump off job and the rear mains cap removed.
Thanks rodp. So I'll need to make sure that if the crankshaft is worn, it's done at the same time as the seal? Useful advice.
They'll lose some fluid but not all. |
Then they think it may be the same case?
Nope, the ZF6 on the 4.2 jag engine uses Lifeguard6 which is clear/straw coloured. If the patch develops over days it's almost certainly the sleeve... |
Guesses?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
I would go with 1 on that list.
