Home > Technical (L322) > Oil Leak - Further Info please.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
After an investigation by my local authorised LR dealer they have identified a slight oil leak from the 'rear main'. Can anyone give me any further explanation on this please?
The joint between what and what is leaking for instance?
I have seen the leak from underneath (whilst vehicle was up on a mate's lift) and it is more of a 'weep' than an outright dripping leak. Still, it's an expensive repair.
Post #447796 14th Aug 2017 12:09pm
MattC
United Kingdom 2011 Range Rover Vogue SE TDV8 Alaska White
The o rings fail and let oil weep through- the leak will only get worse the longer you leave it. The o rings are only about 30p each x 2 and the repair takes around half a hour.
Post #447808 14th Aug 2017 1:26pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi,
I'll think they talking about the crankshaftseal, the seal in the torckconverter or the front seal in the autobox.
If so they have to remove the autobox.
Hope its not that. Expensive job to do its a lot of work.
But maybe its a leaking valve-cover seal?
Piet
Post #447809 14th Aug 2017 1:31pm
Gyre8
OK, Thanks both. Yes, LR have quoted me £848 to repair the leak - 5 x hours labour. If they have to remove the gearbox, will they have to change the gearbox oil in it?
I was thinking of getting this done anyway, so two birds with one stone, etc.
Post #447812 14th Aug 2017 1:39pm
MRx4
Spain
I found this, after five days parked Big Cry
Maybe it's the same
Any suggestions Crying or Very sad Range Rover, what else
RR C 3.9
RRS Sch 4.2
RR Sch 4.2
Post #447828 14th Aug 2017 3:16pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
Not sure which engine you have there. It looks to me like ZF6 transmission fluid, which will probably be the O rings on the electrical sleeve.
A straightforward fix if that is the case....
Post #447843 14th Aug 2017 6:32pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
In garage talk the "rear main" is the seal at the rear of the crankshaft where it comes out the back of the engine. On some engines it's just a round seal that's removed and a new one knocked in, on others it's a sump off job and the rear mains cap removed.
On all it's a gearbox out job.
Now the bad news, it's not uncommon for the crankshaft to have worn where the seal runs, sometimes repairable with a speedy sleeve, sometimes not. Some garages will just replace the seal on the worn bit and you're back to square one in a short while. Crying or Very sad
Post #447847 14th Aug 2017 6:39pm
Gyre8
Thanks rodp. So I'll need to make sure that if the crankshaft is worn, it's done at the same time as the seal? Useful advice.
Also, does this mean the gearbox fluid will have to be replaced as a result of removing the gearbox? I presume yes, but I've read some are gearboxes are sealed, so a bit unsure.
Post #447849 14th Aug 2017 6:49pm
rodp
They'll lose some fluid but not all.
Post #447852 14th Aug 2017 7:08pm
MRx4
Spain
Then they think it may be the same case?
Unsolicited:
RR Sch 4,2 MY06
By the way, the falling oil has the same odor and color as the engine oil. Confused
The Dexron III should be red Range Rover, what else
RR C 3.9
RRS Sch 4.2
RR Sch 4.2
Post #447881 14th Aug 2017 9:55pm
unsolicited
Nope, the ZF6 on the 4.2 jag engine uses Lifeguard6 which is clear/straw coloured. If the patch develops over days it's almost certainly the sleeve...
Post #447954 15th Aug 2017 6:50pm
MRx4
Spain
Big Cry Well, tomorrow to the head doctor.
Direct to the workshop.
I can drive it like this or I should call Tow Matter Wink
I will comment on how the story ends.
Thank you very much for the information. Range Rover, what else
RR C 3.9
RRS Sch 4.2
RR Sch 4.2
Post #447993 15th Aug 2017 11:04pm
MRx4
Spain
Chapter II
Exactly as the gurus said
The part was changed and also the transmission fluid
However, the following occurred:
When starting without problems, the car in D, does not change speed
Passed the change to manual, does not exceed 3
And transmission failure appears.
Back to the mechanic
What should be done? Range Rover, what else
RR C 3.9
RRS Sch 4.2
RR Sch 4.2
Post #449009 24th Aug 2017 10:20pm
unsolicited
Guesses?
Either :-
    1) The new sleeve isn't seated correctly (the electrical connector then gets an intermittent or partial connection)
    2) The garage didn't follow the oil level fill procedure when adding the replacement oil
    3) The garage has broken some of the wiring when they did the sleeve
    4) The transmission has been damaged by static electricity when the sleeve was done
In order of likelyhood...
Post #449096 25th Aug 2017 7:37pm
I would go with 1 on that list.
if it was working correctly before then they broke it.......
they need to fix it. Getting the sleeve into position is not really easy... There is nothing that can't be fixed with a hammer😜😜
Post #449113 25th Aug 2017 9:37pm
