![]() | Home > Technical (L322) > Lost all keys |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 811 ![]() ![]() ![]() |
My son is in England at the moment, I was going to get him to look in to it,
OK thanks |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
A little bit of progress.....
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
When you offer the key to the ignition if there is no sound on the steering coloum this usually means immobilizer fault |
sorry duplicated a post here |
Hi Lukie, still hanging in there with this one then !!
I went to a car similar to this in the summer, the guy had paid £250 For an imobbilizer chip for his fatty, the guy who programmed it gave him a video showing it being programmed
hi Lukie, thanks for your continued support and interest, the unit in the car is not an EWS module but the later immobiliser unit, the second guy who came out said he could see where the immobiliser unit had been soldered on the connections by the previous programmer, does that sound correct ?
Unnecessary quote removed
ECU pic added, what do you think ?
Sorry for delay, will do a little poking around now I have the chip number and will get back to you, i am in the process of buying iid tool pro which I believe program all keys |
No problem and thank you, your help is much appreciated.
Sadly not able to find much out, maybe best solution is to get a new unit (replacement with transpoders) |
Thanks for checking Lukie, the 2006 build is a bit of an odd ball due to the mix of Jag HS CAN components and the older BMW Electronics.
