![]() | Home > Technical (L322) > FBH - a Range Rover story |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 800 ![]() ![]() ![]() |
O,
With the earlier L322 models they're so you can get in a warm car in the morning before the engine starts, they came with a remote, although according to webasto modern diesels don't give off much heat for the heater matrix so they put them in for heat when the car is running.
OK, thanks |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi all , i have a fault on my FBH , circulation pump open circuit or short circuit to battery fault code 0x0034
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Sounds like you need the pump i replaced as per the thread 2007 Vogue TDV8 with 255/55/20's fitted |
Thank you i will get indie to have a look. Engine was out 6 months ago so i was hoping he forgot to connect something !!! 2015 4.4 AB
standupking36 Member Since: 30 Jun 2017 Location: lincolnshire Posts: 76 ![]() ![]() ![]() |
thank you kid sir for your efforts |
well im new to all this tech stuff on these, so reading has prompted me to go try ours (didn't no i had such toys) so i've found said key fob, pressed the on button & just like magic i herd a fan kick in |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
@johnyboy54321 - so is it still working? Still in the Mrs good books? |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
This thread is a great help 👍 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
Since we’ve been having some very cold mornings, I decided to fire up the FBH a couple of times. Each time I try it, the fob goes green and I can hear it fire up but after a few minutes, it stops, having done no heating at all.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3238 ![]() ![]() ![]() |
I would suspect it means your battery is not sufficient power to continue - the FBH is a big drain. |
I did think of that as a possibly but the car was fully charged via my C-tek charger. Got - 2017 SDV8 Autobiography in Loire Blue
