Home > Maintenance & Mods (L322) > Bumper mounted spot / driving lights
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Hi guys, I've seen, to my surprise, a photo of a MY10 updated car with bumper mounted spot lights; I did some surfing on the Net and found the LR factory brackets on EBAY including fitting instructions showing the updated bumper front; so I bought them and will fit after market lights to the factory brackets. My question is for the MY10 models and later - if you did fit the factory spot light kit - where was the switch mounted? In pre 2010 models a new Dash faceplate and switch came with the lights. But the 2010 onwards dash has no space for the switch. 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #450259 8th Sep 2017 10:36am
what about the spare slot in the console where the sunroof switch is....you could buy and use the switch thats meant to be for the deployable steps for your lights.. ... - .- -.
Post #450262 8th Sep 2017 10:58am
j_rov
Re: Bumper mounted spot / driving lights
Unnecessary quote removed
Could you post a link of that photo please? I'd be interested in some myself.
Regarding switching, i'm sure I've seen a picture combined switch for this which replaces the fog light one... will see if i can find it again. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #450263 8th Sep 2017 12:29pm
BlackPerth
Stan, did you mean up on the roof console? Yes, good idea, that is an option. I hadn't realised that where the deployable steps button went; cant see it in the handbook.....??
Re the changed spotlight switch - interesting!!
On TOPIX there is no indication of the Lamp Kit so I wasn't sure where to look next. I wonder if any old Brochures show the switch.
cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #450337 9th Sep 2017 2:48am
BlackPerth
Photo of 2010 car with lights:
Post #450339 9th Sep 2017 2:53am
BlackPerth
Switch
Stan, any idea how I find a part number for the deployable steps switch? 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #450340 9th Sep 2017 4:36am
you can ask dan @ duckworths ...but as it's a blank plastic cover in the console you could make a hole in the cover and fit any switch... ... - .- -.
Post #450345 9th Sep 2017 8:08am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I am interested
Can you post eBay links please
However I already have deplorable side steps
Where might I put a switch ?
Post #450353 9th Sep 2017 9:57am
Baltic Blue
You could tee them into the existing small front spots?? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450354 9th Sep 2017 10:08am
....or get the feed from the halogen main beams and use a relay... ... - .- -.
Post #450363 9th Sep 2017 10:35am
BlackPerth
Rambles, check out:
http://www.ebay.com.au/itm/LAND-ROVER-DRIV...2749.l2649
No idea where switch goes...trying to find out......
Rambles, can you prize out the Deployable Steps switch from its location and tell me if a part Number is on it?
Post #450427 10th Sep 2017 2:39am
Rambles
Thanks for the link
I think that offer is now expired.
I don't think it would have worked on MY10-12.
It states it is for 03-09.
Only link I found was this for an A bar.
But it's expensive
And looks horrible.
https://www.devon4x4.com/range-rover-l322-...05239.html
Couldn't find a part number on the switch.
I called LR Bromley who fitted my deplorable side steps and asked them.
Apparently the part number is for the whole unit. LR don't sell bits and pieces from the install kit.
Post #450433 10th Sep 2017 8:31am
supershuttle
I had a set up like this on my Mk1 Cortina GT (happy days) I just wired straight to the battery via a relay which was operated by the main beam feed. I also incorporated a switch (under the bonnet) so I could have them not come on with main beam but I hardly (if ever) used it - when I needed main beam I needed as much light as possible. Obviously as the relay only operated on main beam they went off when dipped. No need to make this difficult Thumbs Up Geoff
Post #450434 10th Sep 2017 9:03am
BlackPerth
Bumper lights
I know it says to 2009 BUT the instructions clearly show the 2010 facelift the whole way through so I am positive they will fit.
Post #450509 11th Sep 2017 12:29am
DallasRob
United States 2008 Range Rover HSE 4.4 V8 Tonga Green
BlackPerth, do you know what lights are mounted on the 2010 RR you posted? I like the size and the gray trim rings. I don't think those are the lamps from the LR kit VUB001090.
Post #462543 28th Dec 2017 11:25pm
