![]() | Home > Maintenance & Mods (L322) > Bumper mounted spot / driving lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35860 ![]() ![]() |
what about the spare slot in the console where the sunroof switch is....you could buy and use the switch thats meant to be for the deployable steps for your lights.. ... - .- -.
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389 ![]() ![]() |
Unnecessary quote removed
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
Stan, did you mean up on the roof console? Yes, good idea, that is an option. I hadn't realised that where the deployable steps button went; cant see it in the handbook.....??
Photo of 2010 car with lights:
Stan, any idea how I find a part number for the deployable steps switch? 2017 Range Rover Vogue SE SDV8 (with e-diff)
you can ask dan @ duckworths ...but as it's a blank plastic cover in the console you could make a hole in the cover and fit any switch... ... - .- -.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
I am interested
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
You could tee them into the existing small front spots?? G reg 2.5VM Vogue Portofino red 1991- 1999
....or get the feed from the halogen main beams and use a relay... ... - .- -.
Rambles, check out:
Thanks for the link
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
I had a set up like this on my Mk1 Cortina GT (happy days) I just wired straight to the battery via a relay which was operated by the main beam feed. I also incorporated a switch (under the bonnet) so I could have them not come on with main beam but I hardly (if ever) used it - when I needed main beam I needed as much light as possible. Obviously as the relay only operated on main beam they went off when dipped. No need to make this difficult |
I know it says to 2009 BUT the instructions clearly show the 2010 facelift the whole way through so I am positive they will fit.
DallasRob Member Since: 28 Dec 2017 Location: Dallas, Texas Posts: 10 ![]() ![]() ![]() |
BlackPerth, do you know what lights are mounted on the 2010 RR you posted? I like the size and the gray trim rings. I don't think those are the lamps from the LR kit VUB001090. |
