Home > Technical (L322) > water
Page 2 of 3 <123>
p38arover
Australia
I'll be following the timing chain job if you keep posting about it.
Do you have to remove the through-sump drive shaft or is there a lower cover below that? I should go and read RAVE. Very Happy
Re the thermostat mod, I've done it but I think, if I was considering it now, I'd just buy the bolt-on lower temp housing that doesn't have the heating element. It's been shown in another thread. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451089 16th Sep 2017 11:33am
p38arover
Australia
I looked at RAVE. It might be worth dropping the lower sump cover to see it there is any plastic chain guide in there. Perhaps when I do the next oil change. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451091 16th Sep 2017 11:48am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
that would be worth thinking about RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #451093 16th Sep 2017 12:34pm
knares
From what I can see and I am properly wrong but the earlier housing and thermostat which was fitted to the earlier models, the thermostat was 10mm shorter, if this is correct, then it would be no good.
The closest I have found so far is this one, it is 82mm dia, would be better if it was 84mm
The base is 51mm, the original is 43mm
http://m.dayco.com.au/PartInfo.aspx?P=DT101A
I would like to see the other thread if you remember where it is
thanks RR 2005 4.4 petrol
Post #451182 17th Sep 2017 2:26pm
p38arover
Australia
This is a quote from this thread: http://www.fullfatrr.com/forum/topic39362.html
MarkNL wrote:
http://www.onderdelenshop24.com/7016322-behr-thermot-tronik
Anybody out there who ordered this part yet ? Its the BEHR thermostat model TI 3288 for the 740 diesel.
BMW part number is OEM NUMBER 11512248542 THERMOSTAT / opening at 88 degrees...
Has the exact same dimensions and design as the BEHR thermostat TM 12 105 --- this is OEM number 1153 1 436 386 / for BMW / opening at 105 degrees ... which is the same as "our" original OE PEL000060 / for LAND ROVER
Hope to hear more....
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451184 17th Sep 2017 2:32pm
knares
yes, thanks, i have seen that post befor
what worries me is the flange to the base looks to short, in the photo
if it is, then it is not going to shut off the bypass when the thermostat is open RR 2005 4.4 petrol
Post #451185 17th Sep 2017 3:07pm
knares
 RR 2005 4.4 petrol
Post #451186 17th Sep 2017 3:08pm
knares
OK i got the thread now RR 2005 4.4 petrol
Post #451187 17th Sep 2017 3:13pm
knares
yes that looks like the way to go
they are 48 pound
i Tried to buy one but I don’t have an account RR 2005 4.4 petrol
Post #451188 17th Sep 2017 3:26pm
knares
Removed the crankshaft boss to day
I had made a flange to bolt on to the boss during the week, it fitted nice and snug and I bolted it on with the eight bolts.
I removed it and welded a bar on it, so it would jam on the chassis
When I replaced it, it was a bit tighter fit, the welding had shrunk it slightly, that’s normal.
I removed the boss bolt and then I removed the flange and then the boss.
The boss was quite loose on the crank I thought.
Although I didn’t think the flange was to tight a fit on the boss, it must have been as it broke part of the locating collar off the boss.
The boss is made of cast iron, not steel
SO, I am up for a new boss. RR 2005 4.4 petrol
Post #451830 23rd Sep 2017 2:14pm
holidaychicken
https://www.germanautosolutions.com/diy_te...ls_diy.php
http://www.beisansystems.com/procedures/m62tu_vanos_procedure.htm
I used the above guides combined with Rave manual and there is a complete guide on you tube that I used that was about 10 videos long that was really helpful.
I labelled every wire I unplugged and every bag of nuts or bolts.
I also took about 100 photos
Good luck
Post #451901 24th Sep 2017 9:05am
knares
thanks for the links
i could do with the computer next to the vehicle
i orderd a timing tool kit this morning, it looks a different tipe to that one RR 2005 4.4 petrol
Post #451917 24th Sep 2017 12:15pm
holidaychicken
That's not the type i used, mine was like the ones off ebay, about £120, i had an old laptop out in the garage with me but no internet connection unfortunately.
Post #451940 24th Sep 2017 4:43pm
knares
yes, they look like the ones i have ordered
$121.00 on ebay.au about 71 pound
there is fourteen pices in the kit
did you replace all three chaines RR 2005 4.4 petrol
Post #451973 25th Sep 2017 1:40am
holidaychicken
I replaced all 3 chains although none of mine showed any wear really at 110k miles and I replaced the cam chain guides as well as all the timing chain guides of course but even the timing chain guides looked fine but mine has never been on lpg which is my theory that the higher engine temps makes the guides brittle.
I replaced the valley pan with a new febi one as it comes with the gasket sealant already applied and I changed the PCV valve while I was there as it was easy to reach.
Depending on your kit, you may need to modify the flywheel locking tool as the BMW uses a straight locking pin where the L322 needs a 90 degree pin, you can see my modified pin and also where it protrudes through the flywheel on the other side.
This is the crank holding tool I used for the insanely tight crank bolt
http://www.ebay.co.uk/itm/161280308528
Post #451974 25th Sep 2017 2:00am
Page 2 of 3 <123>
