![]() | Home > Maintenance & Mods (L322) > Dashboard thinks it's Christmas |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
Most likely you need a new battery.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
I change mine every two years regardless - have the battery tested but a new one is not a bad investment anyway |
| lawsey Member Since: 28 Sep 2015 Location: newcastle upon tyne Posts: 65
varta battery the big one fitted last November. 13.5volts coming from alternator. Charging light remains on. |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
13.5 sounds low to me pal , id expect 13.8-14.2 with engine running |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Have the battery tested first.
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
Yep, I agree with Bembo - alternator should be charging at at least 14V preferably more. Bish.
Car on with the MD they suspect alternator failure. anyone ideas at likely costs. £110 per hour thought they would have a better idea than suspect?? |
I surprised you took it to an MD for that pal , rob dogs ! |
New denzos are about 700 quid replaced mine on 4.2 supercharged the other week at ten years was ok but new one is belt and braces |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Shocking price really. A new alternator for an MG Midget is £60 and fitting time of no more than 20 minutes! .
| gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162
You can buy the Denso from ECP for around £210 by the way.
| All times are GMT |
