|  | Home > Maintenance & Mods (L322) > Brake Tin Rattle Help Please |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | if its the bit a think you mean then you need to remove the wheels and tighten..cant remember if its from the rear or behind the brake disc.. | ||
|  9th Jan 2011 11:30am |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | this is a great vid on how to change your brakes. It also shows somewhere the brake protector shield which you refer to, so should allow you to access it and tighten up.
|  9th Jan 2011 12:56pm |
| Reformed Member Since: 09 Oct 2010 Location: South Posts: 471    | Thanks guys!
|  9th Jan 2011 4:46pm |
| RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48      | My one corroded through at the fastening points - I also used the tin snips to cut it off - those 16mm carrier bolts where too tight (broke a socket) so I give up - I was going to fit a new spash guard in the warmer weather to - that was a year ago - must do it some day  | ||
|  9th Jan 2011 7:36pm |
| KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95    | I had the exact same problem the other day, This can be fixed without removing the brake disc etc. Simply get a large diameter washer for each bolt that the tin splash guard has seperated from. Undo the bolts and redo with the washer in inplace and tighten. Its a tight finger sqeeze to do,but saves so much time.
|  9th Jan 2011 11:38pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | You have to remove the hub assembly to replace the back plates, easier said then done.
|  12th Jan 2011 1:38pm |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3819    | for those that don't know, never ever weld (especially arc weld) on a vehicle without disconnecting the battery and or alternator - otherwise it is more than likely you will blow it or both. | ||
|  12th Jan 2011 5:05pm |
| Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011      | And don't forget to have a fire extinguisher to hand, ask me how I know this..........   | ||
|  13th Jan 2011 8:54am |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936    |
 How do you know this Richcl?  Ian | ||
|  13th Jan 2011 11:24am |
| Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011      | Um   | ||
|  13th Jan 2011 11:42am |
| kineavy Member Since: 21 Dec 2015 Location: Cambridge Posts: 33    | Noticed this on my FF yesterday and I think I will go down the tin snips route. Just going to go Screwfix this morning to invest in one.
|  8th May 2016 7:43am |
| Posting Rules
 ....Discovery (Mine luckily!) welding rear sill.....could see flames behind patch I was welding, thought I'll just blow that out (probably fed the flames!
