![]() | Home > Maintenance & Mods (L322) > Car back not for long |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Update maybe right side head gasket leaking between a port as the pulse on the on the front pipe breather is weak where the left is strong took a video of engine minus right turbo and egrs , pretty sad another two weeks to use a Picasso.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
you're not having much luck recently Scott... |
IM trying to be positive and think its been a fantastic car apart from this blip and ah well no ones died or got any illness's its just a car that can be fixed |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8087 ![]() ![]() ![]() |
Ouch !
labours only £35 phr and already in this month for turbos and valves at 2k so another £1500, i still cant get the 5-0sc with right colour/spec less than 60k and that's a 13 plate, tbh i cant justify mortgage payments for a car and lose money when i would rather buy another house and rent it out at the minute. I will get one eventually in a few years if it goes to plan |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
so you keep paying the garage to mis-diagnose and repair your FF ? |
Mis diagnosed? Turbo went and actuator and left turbo followed changed valves as precaution and then made a pop now engine out the gaskets gone between 3 and 4 port I’ve seen today so where’s mis diagnosis please tell, a bit unlucky for gasket to go but then these can be it’s the par unfortunately, could be worse at least a stealer isn’t lining his pockets |
