Home > Maintenance & Mods (L322) > Car back not for long
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Excited as car was ready so went to collect it and it started to whistle left side as he started it iin the workshop,he thinks it’s the manifold inlet gasket or is he hoping do you think it’s more like a fault on the turbo? Any thoughts chaps Sad _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #452321 27th Sep 2017 11:10pm
Scottyav
Update maybe right side head gasket leaking between a port as the pulse on the on the front pipe breather is weak where the left is strong took a video of engine minus right turbo and egrs , pretty sad another two weeks to use a Picasso.
https://vimeo.com/236052874?ref=em-share _____________________________________________________
Post #452434 29th Sep 2017 10:47am
you're not having much luck recently Scott... Sad ... - .- -.
Post #452442 29th Sep 2017 12:15pm
Scottyav
IM trying to be positive and think its been a fantastic car apart from this blip and ah well no ones died or got any illness's its just a car that can be fixed Neutral _____________________________________________________
Post #452452 29th Sep 2017 2:04pm
Ouch !
Engine out for the head gasket - I was quoted 22 hours labour on my old 3.6 TDV8
So I did the sensible thing & bought an L405 SDV8 & sent the L322 off to the auction....
Post #452454 29th Sep 2017 2:38pm
Scottyav
labours only £35 phr and already in this month for turbos and valves at 2k so another £1500, i still cant get the 5-0sc with right colour/spec less than 60k and that's a 13 plate, tbh i cant justify mortgage payments for a car and lose money when i would rather buy another house and rent it out at the minute. I will get one eventually in a few years if it goes to plan Thumbs Up _____________________________________________________
Post #452543 30th Sep 2017 2:58pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
so you keep paying the garage to mis-diagnose and repair your FF ?
Post #452548 30th Sep 2017 4:44pm
Scottyav
Mis diagnosed? Turbo went and actuator and left turbo followed changed valves as precaution and then made a pop now engine out the gaskets gone between 3 and 4 port I’ve seen today so where’s mis diagnosis please tell, a bit unlucky for gasket to go but then these can be it’s the par unfortunately, could be worse at least a stealer isn’t lining his pockets Cool _____________________________________________________
Post #452587 1st Oct 2017 12:04am
