Home > Maintenance & Mods (L405) > L405 Rear brake pad replacement 2014 model
Page 1 of 4 1234>
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi
I have had the mad idea to replace the rear brake pads and sensor on my 2014 model.
I have found out how to switch the electronic handbrake into service mode.
I know how to remove the two retaining bolts to remove the calliper.
Where I am struggling is how to compress the piston. It's not as simple as compressing the piston but I am lead to believe, you need to compress and rotate the piston - Is this correct and is it clockwise or anti-clockwise. Rolling Eyes
Can anybody help - without saying take it to a mechanic...... Shocked
Thanks
3.0 14M5 Autobiography
Post #451926 24th Sep 2017 2:14pm
Mariana Black
Managed
Having watched various videos on YouTube and doing what I thought.....
After placing the hand brake in maintenance mode I just needed to push the piston and did not need to twist either clockwise or anti clockwise. I did buy a windback tool and found this very helpful.
I hope this information helps with any other mad DIYers when replacing the rear brakes.
Thanks
3.0 14.5M Autobiography
Just out of interest - I also replace the front disc and pads and again the windback tool was useful. (Double piston on front - placed one old brake pad in the caliper and used that as a bridge to both pistons. It was tight then loose and then tight again.
Cheers Thumbs Up
Post #452561 30th Sep 2017 8:17pm
Steve j
United Kingdom 2013 Range Rover Autobiography TDV6 Luxor
You say you bought a wind back tool, I believe these do twist in the plunger as it goes back, not just push them back?
Maybe wrong.
Steve
Post #469728 22nd Feb 2018 10:54pm
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
Had this recently on my 14my, the piston also has 3 pins for the wind back toll to lock into when pushing it back - fairly rare apparently. Laser do a tool with 3 adapters and adjustable pins which l have...... now !! Model 6329. Other than that all quite straight forward.
Keith Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #469760 23rd Feb 2018 10:28am
Mariana Black
Hi
I have changed the front disc and pads and also the rear pad on my 2014 big boy. Thumbs Up
Yes the piston has a three pin connection which I bought an adapter from Machine Mart.
I think even though I had bought the tool it only needs a very good compress, the turning action was not needed.
Remember to set the car in maintenance mode for the rear brakes, it took me a while to find the way to do this.
Hope this helps Very Happy
3.0 Autobiography 14M5 (49K miles)
Post #470044 25th Feb 2018 8:43pm
As has been mentioned above the car MUST be put into maintenance mode or you will have a VERY EXPENSIVE rear calliper replacement for your troubles Whistle Whistle Whistle Rolling Eyes
Post #470097 26th Feb 2018 12:33am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
so how is it put in maintenance mode then ?
Post #470213 26th Feb 2018 11:47pm
Via a diagnostic machine sir... Thumbs Up
Post #470214 26th Feb 2018 11:49pm
Fleagle_UK
Can the IID tool from Gap do that then ? - I have one of those.
Post #470663 2nd Mar 2018 11:02am
Yes sir it can...
Post #470667 2nd Mar 2018 11:29am
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I'm about to do mine so have looked into the service mode. I've discovered that this can be accessed without a diagnostic machine as follows:
- Turn the ignition ON (not the engine) by pushing the start/stop button without stepping on the brake pedal
- Push the e-brake button down for 2 seconds and hold it (release the e-brake)
- Push the accelerator pedal down for 2 seconds and hold it
- Push the start/stop button twice (turn the ignition off and on)
Now the e-brake service mode is active.. you will hear a noise from the rear e-motors, when its releasing the e-brake to the service mode. Still hold the e-brake button and the accelerator pedal.
After the e-motors stops there will be info on the dash that the e-brake service mode is activated.
To deactivate the service mode is the same procedure, the only change is that you have to pull the e-brake button.
Have tested on my 2013 L405 and it works! Thought this would be useful info for anyone else considering a bit of DIY.
Post #493590 25th Oct 2018 6:57pm
Fleagle_UK
Iid tool giving error E7
Does anyone else iid tool give error E7 when using it to try and set the rear brakes into maintenance mode?
Post #506634 27th Feb 2019 11:48pm
Mariana Black
Hi
I put my car in service mode without the use of a IId tool. Just by pressing buttons and the pedals in the correct order.
Post #506739 28th Feb 2019 9:49pm
Fleagle_UK
Yeah Using that approach works fine. I just wanted to know if anyone else had the same problem with their iid tool or is the problem unique to mine.
Cheers
Post #506744 28th Feb 2019 9:58pm
Fleagle_UK
Did my rear brake pads and discs today.
Just to add a few useful points for anyone else who does their own brakes.
1) the driver side is the wheel with wear sensor. I would always fit a new one as I have never managed to remove it from the old pads without it breaking apart.
2) pressing the caliper pistons back into the caliper. Using a good compressor the driver side pushed back in no effort at all. Despite the piston crown having having slots for a wind back tool - it just pushed in easily no wind back needed.
The passenger side though was a different story. This piston would NOT compress back whatsoever. After double checking the epb was still in service mode (paranoid!!! Shocked ), a trick I learnt years ago -is pair of long nose pliers fit into the wind back slots and gives you enough purchase to turn the piston - no special tool needed. The piston turned a quarter turn clockwise then locked. After that it compressed easily.
No idea why the two sides were different or if it was a flook or if sometimes a piston spins &locks over time and some don’t. Dunno.
3) to remove the old disc you will need a size T50 TORX bit (not socket) to remove the disc retaining screw.
4) a final point, the sensor wire feeds up to the back of the shock absorber high up and is a Censored to see the socket it connects to. It’s even more of a Censored if you have big fat shovels for hands like me as there isn’t much space to work to disconnect the old one and plug in the new one. Patience and you’ll get there.
Hope that helps anyone. Fairly straight forward job using LR parts from Dan, and a saving of about £200 on what my local LR dealer wanted.
Post #508329 11th Mar 2019 8:21pm
Page 1 of 4 1234>
