![]() | Home > Technical (L322) > Replacing the rear diff? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
here is the howto from RAVE for earlier models
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
Cheers for that Joe, looks like it can done during lunch break!! |
Might also be worthwhile getting new bushes for the diff, while you have it off, and of course some lovely new rear axle fluid. Make sure you can undo the filler plug before undoing the drain plug and draining it though. .
Yeah, good idea.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
those few pages dont seem to mention the halfshafts out (or did I just not see that bit ? ) They'll need to come out the sides of the diff too.
Cheers for that.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2724 ![]() ![]() |
Pulling the half-shafts back far enough with the hand-brake cables still attached was quite a struggle when my son and I swapped mine's open diff with an e-diff.
Thanks for that. Porsche 911 (996)
@ fisha, it is there, Page 2 items 12-14 and an image |
Ah ha! so it is! I was looking for pictures where the halfshaft slides right into the diff. Didn't realise the driveshafts just bolted onto the diff a bit like a propshaft. V8 or else ... |
No they don't! Page 2 steps 17 and 18 refer to the half-shafts but no picture other than of the lower wishbone bolt to be removed. |
We are all wrong!
